  #61
Old 02-26-2012, 09:34 AM
  #62
Old 02-26-2012, 03:09 PM
waggoner5's Avatar
Cool. Like the shifter mod.
  #63
Old 10-24-2012, 05:00 PM
rockrod rockrod is offline
Update time:
Emissions testing is in process. I went to the tech center in Littleton about a week ago and failed the inspection. Why? Because the I/M readiness monitors were showing 'not ready'. This was due to the battery deciding that was the day it was done. They had to jump the truck to get it to start so that I could leave.
So - new battery is in place, but now I am getting an occasional P0455 code which shows 'gross evap leak'. At first I though it was truly a leak and went through a bunch of test to try and find it. Turns out it was the evap vent valve was not getting the required B+ voltage it needs. I fixed this last night and the CEL went away this morning.
I am still showing the evap is not ready and also the O2 sensors are showing not ready. I put a pair of new Denso sensors in last night as well. Hopefully they will go to ready in the next few days. It's hard trying to get into the correct drive cycle because there are not many roads that allow for a 6+ minute uninterrupted cruise a 55 mph.
The center also said my 315s are too big for the rollers....
2004 Kona Stinky dee-lux.
  #64
Old 10-24-2012, 05:01 PM
Update time:
  #65
Old 11-01-2012, 01:15 PM
update
I went back today after all of my readiness monitors switched to ready and I passed the state inspection. The HP Tuners software is the bomb.
I then went next door to the Air Care station and PASSED! They even ran it on the rollers with the 315s on it. These tires measured out at 34.5 which is technically over their limit but when I asked the guy about this, he looked and said that if the tires will fit onto the rollers and not rub on the side of the guides or try to climb over the blocking rollers, then it's good to go.
The cruiser passed. It even passed with the quick test and was on the rollers for about 30 seconds total before the test ended. So get this, my 1994 Toyota Land Cruiser is considered a 'very clean' vehicle since it did not test out for the entire 240 second test and was 'fast passed'.
My numbers are:
HC .4607 Max 1.20 GPM
CO 7.12 Max 15.0 GPM
NOx 1.7105 Max 2.0 GPM
Note that they tested the cruiser at the year model 2000 and greater standards and not the 1994 standards.
The guys gave me high fives, I paid my $25 and was on my way.
The cruiser is now officially 'legal' in the eyes of Air Care Colorado.
  #66
Old 11-01-2012, 01:43 PM
Congrats on all the hard work and e-test success!
  #67
Old 11-01-2012, 02:21 PM
indeed
  #68
Old 11-01-2012, 02:40 PM
Congratulations!
Glad you have it finished and running well You know it may sound weird, but I don't mind the emissions test post swap... I feel like it forces you to get it all working like it is supposed to.
Also, I agree, HP tuners is great. I am not sure I could have ever finished my swap without it. Using it as a diagnostic aid alone really really helps. Not to mention the fact that you can fine tune crapola.
  #69
Old 11-01-2012, 03:02 PM
Congratulations!
i should have invested in the software when I started this swap. I learned pretty quick that having to depend on someone out of state to make simple changes was pretty lame. I even bought a second PCM so that I would not be without a vehicle when making changes.
The software is cool. It's so easy to go in and do a scan and record a drive cycle and then play it back and make the changes where it needs it. I found out that a tune for an iron block 5.3l is not the same as the aluminum L33. The half point in increased compression makes the L33 very prone to pinging. Also, the difference in the air intake track skews the MAF output which in turns jacks up the LTFTs. I have had to dial that in as well. None of this could be done with a mail order tune.
I also like being able to fine tune the shifting characteristics of the 4L60e. That feature alone is worth the price of admission. I am going to develop secondary shift pattern that will activate through the tow/haul mode
  #70
Old 11-01-2012, 04:33 PM
HA! I bought a secong PCM as well. Sending my PCM out of state over and over was horrible.
I also had to fine tune my MAF sensor to get rid of LTFT issues.
And yes, there are different tunes for all of them. surprisingly some tuners don't get that. It is actually surprising how little they know sometimes about something you'd imagine is pretty well known.
having a manual tranny I also played with how aggressively it holds idle with the idle air bypass.. made crawling a bit easier I think Rubicons do something similar.
It'll be cool to see what you come up with with the tow/haul shift stuff, that's a good idea
