Old 12-23-2011, 09:16 AM
Default Spaceballs
Mysterious 'Space Ball' Crashes in Namibia
That's an Imperial probe droid.
It's a good bet the Empire knows we're here.
Start the evacuation.
Old 12-23-2011, 09:46 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
but that was a long long time ago, but some how in the future.
i already read that artical,, but to me it looks like a bouy
TLCA # 20314
Step by Step Bed Bob
Old 12-23-2011, 09:58 AM
Romer Romer is offline
Thats what a typical fuel tank looks like on a satellite. They use Hydrazine for fuel, pretty nasty stuff.
Old 12-23-2011, 10:02 AM
sno bored's Avatar
sno bored sno bored is offline
Maybe it's a meteor, like this one I found back a few years ago.
Old 12-23-2011, 11:25 AM
That's what it looked like to me, too, a propellant tank. I think the explanations people come up with are great.
In case anyone wonders, they are made to handle about 600 psi through pretty crazy vibe and shock. Made usually of 6/4 titanium, probably about 0.125" thick. They're sometimes insulated with graphite fabric, which would burn off, although the tank itself is fairly robust. They reckon maybe a couple of dozen from satellites have come home to Earth over the years, although most probably are destroyed. Maybe this one had some hydrazine left in it that absorbed the heat and didn't burn up.
Here's one probably very similar on the upper stage of an Ariane V. These are recovered or end up at the bottom of the ocean.
Another on the ESA Galileo bus. This one is much bigger because it has to last for years.
Old 12-24-2011, 10:00 AM
