Old 12-27-2011, 12:26 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Question Missing/Hesitation
Hi All,
I need help trying to identify the source of a new problem.
my 1996 FZJ80 with 172K miles just started hesitating/misfiring. What might be the problem?
It doesn't blow blue smoke and doesn't have a history of this problem. I do get the P0401 code a lot but I believe it's just the sensor - not an actual problem
I just drove it 2200 miles to Florida. Along the way we drove it hard at upwards of 70 mph for extended periods of time. Frequent taking it in and out of overdrive to gain more power on uphill climbs
The problem seems to be more noticeable when it's just started, but honestly I haven't driven it enough since getting here to know if happens all the time.
My chief concern is if it's safe/ready to drive back to Colorado.
Thoughts?
Thanks!!
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 12-27-2011, 12:30 PM
Start looking for easy stuff.. any plug wires loose? Any vacuum lines loose or missing? Is the big air intake tube cracked? just ideas... good luck!
Old 12-27-2011, 07:10 PM
I agree. Could be ignition related, or fuel delivery related (or combination of both). What's the service history on spark plugs and wires, dist cap and rotor, etc.? Or maybe a clog in the fuel filter? Or injector?
Old 12-28-2011, 11:11 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
check the plugs first.. they will tell you whats going on with the motor.
TLCA # 20314
Step by Step Bed Bob
Old 12-28-2011, 11:35 AM
ttubb's Avatar
ttubb ttubb is offline
X2 ......Look at headgasket issues...bubble test, plug condition and compression test.
KA7TLT - TLCA 13015
Old 12-29-2011, 03:17 PM
What about that mass of wires that some 80 owners have had problems with? I'm not sure where it is, but if gets chaffed and then some of the wires in the bundle can short out causing issues. From what I recall, it is intermittent and often noticed when the engine torques and the wires make contact...lots of threads on MUD as I recall...
Old 12-29-2011, 03:51 PM
That would be the engine harness that passes next to the EGR valve.
Old 01-02-2012, 08:18 AM
Check for loose spark plugs. Do a compression test, too.
Old 01-02-2012, 10:50 AM
TIMZTOY's Avatar
any update ?
TLCA # 20314
Old 01-05-2012, 11:58 PM
LETSROLL's Avatar
Hi All,
Thanks for all the good information. As I was in Florida and had no tools (and very little skill to use them) I sort of monitored/ignored the problem. It seemed to be experiencing the problem off and on and so I figured it was ok to drive home to Colorado.
Earlier tonight I was in Amarillo, TX and started a run up 287 towards Raton Pass when my oil pressure gauge dropped to 0. I popped the hood and saw a fair amount of oil on the shield under the front of the motor. It burns/leaks some oil so that's not that unusual. The oil level was about normal and the truck ran ok all the way back to Amarillo (50 miles back) with the oil pressure never coming up off o but no change to the water temp and no check engine light (other than the P0401 I always get)
Now I don't know if I need to find a Texas mechanic, or assume I just have a bad sensor and get back on the road.
Thoughts?
LETSROLL
TLCA#19430
