Old 07-07-2006, 10:09 AM
IanB's Avatar
IanB IanB is offline
Originally Posted by Rezarf
Ken-
Is your generator bolted down onto the deck? I am only asking because I feel a little sketchy about JB welding the rack pipes into place.
Just wondering, looks like a nice way to camp. See you on the Ghost town run.
Drew
You could easily get that welded up, that way swinging branches can't take it out on the trail. Looks good.
1976 FJ-40
2001 UZJ-100
Old 07-07-2006, 10:46 AM
Romer Romer is offline
The pipes are aluminum and what I added is steele, can you weld al to steele?
Old 07-07-2006, 12:07 PM
IanB's Avatar
No but you can weld in aluminum pipes instead or weld mounting tabs to the steel pipes and bolt them on (or vice versa). I think the JB Weld might be a dissapointment in the long run, but its not important its just a suggestion.
1976 FJ-40
2001 UZJ-100
Old 07-07-2006, 01:13 PM
Beater's Avatar
Beater Beater is offline
you can braze it
Old 07-07-2006, 02:07 PM
Alum to steel? Well, if GM says it, it can be done. I think he is volunteering... I'd bet the alum would fracture at the braze though.
KDěRCH
Old 07-07-2006, 02:54 PM
Beater's Avatar
it won't be that strong, and won't really stand up to hf vibrations. almost like soldering, as you would have to use a low tensile rod.
Better would be to tig on some feet to bolt the railings down with.
j
Old 07-07-2006, 06:37 PM
j
Is this something I can do with solder and a blow torch? Not sure how I would do the feet since the railing now sticks out past the deck. I have the foot that I removed (See orginal pic).
I don't see the railing right there as anything but cosmetic. It won't be used to hold the generator.
Thanks
Old 07-07-2006, 11:49 PM
Better yet, I'll just drill a hole all the way through and run a bolt through it.
