Old 01-17-2012, 11:44 AM
What sort of "services" do you think can reasonably be done in a day?
For instance, on my LX I'm pretty sure I need to replace the tie rod ends (4). Could this be accomplished in a day? Or is something like that better to have done by a shop that can also do an alignment afterward?
Originally Posted by baileyfj40 View Post
Gentlemen, is it possible for me to bring our club trailer down and get some help doing some possibly overdue trailer maintenance repacking wheel bearings on our club trailer?
Thx
No problem, just don't plan on leaving it here
Setting up the 3rd member with the new gears & ARB is no problem
For those that want to just pitch in and help, the more the merrier. It will probably take several pairs of hands to drop the bumper off of Jaderunners rig. If any of you have good fab skills you are welcome to use the plasma cutter and mig welder, or I can do it too.
Thanks Ricardo for stepping in to help manage the process. Remember we have 3 bays and 1 lift so we don't want to over book the space.
Old 01-17-2012, 12:37 PM
Thanks Randy! I take it these sessions are a replacement for the annual WBPP?
  #24
Old 01-17-2012, 12:50 PM
nattybumppo's Avatar
H55f install into an Fj60 Saturday February 11th, with tear-out and clutch work Thursday or Friday evening beforehand! Thanks, Randy!!!
I would love to do some more differential work soon. In fact I am thinking about putting an ABR in the 4.11 rear I got from Matt for the aforementioned 60. If a "high pinion" is not significantly different from a regular diff, I would be happy to help with Mark's project. If it is quite different, well I'm always up for learning while I help, but I may not be considered "experienced".
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
  #25
Old 01-17-2012, 12:53 PM
Yes and no. If you need to pack your wheel bearings any of these sessions would be a good time to do it. I took over the WBPP a few years ago and need to think through if it will/can/should be rolled into these sessions. Perhaps, the best thing to do is re-brand the March or April session as the WBPP.
  #26
Old 01-17-2012, 12:59 PM
Post it up in Session #2.
  #27
Old 01-17-2012, 05:24 PM
I didn't want this to take the place of the official club event WBPP as some folks may be disappointed if that didn't happen and it's typically held closer in to town so the drive isn't as far.
On the other hand, if we want to choose one of the weekends Ricardo has identified and have the official WBPP at my place we can do that too.
  #28
Old 01-19-2012, 07:37 PM
baileyfj40 baileyfj40 is offline
Barring snow I can do most any weekend listed, which one would work for others for me to get the most help with the bearings on the club trailer. I will hook it up and take it to the local auto parts place Saturday the 21st of Jan and see if I can get replacement wheel seals for it.
Mike Koons
77 fj40 lifted locked ready
89 fj62 lifted locked ready
99 F350 reserve hauler
03 F350 crew cab dually the bigger hauler
04 Lance 1121
90 fastiva r.i.p. 336k
01 vw golf daily driver Gone
01 Tacoma double cab
KDDHQ
  #29
Old 01-19-2012, 10:50 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Very easy IF you have the right tie rod end puller - a good one like Ige owns - heat (to loosen the ends from the rod), a big pipe wrench (to loosen the ends from the rod) and access to a vise (also part of loosening the ends from the rod) and the ability to make a jig (I screwed wood blocks to the top of my workbench) so that you can get the tie rod length right. To get my ends out I had to clamp the end in the vise, heat the area at the threads and then stand on my pipe wrench to get them apart.
Still, maybe took an hour total per rod.
  #30
Old 01-20-2012, 06:27 PM
Bring folks that have the knowledge and any special tools required like the puller that Ige has. Also, keep in mind we are doing both Saturday and Sunday on the appointed weekends. You could work on it Saturday and if you run out of time, finish it on Sunday. Just arrange a ride back & forth.
