Old 01-18-2012, 06:53 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
didnt know it didnt have a cat.. i just listened to the first 10 seconds of the video. and the noise is typically what a bad cat sound like
TLCA # 20314
Step by Step Bed Bob
Old 01-18-2012, 10:01 PM
baja1d's Avatar
baja1d baja1d is offline
I've got a timing light, your tranny bolts, and I just put in a garage heater.
Old 01-18-2012, 10:13 PM
bigcity25's Avatar
bigcity25 bigcity25 is offline
1. Yeah it's a weber and had the noise before when I had a stock carb.
2. I have looked for soot and also exhaust puffs and haven't felt anything.
3. Not sure what my timing is but my mileage is bad
4. Ill take up anybodies help on my timing and carb adjustment. Been meaning to meet with Jeff Zepp up in the hills. But haven't had the time to get up there yet.
Just drives me nuts because it's so random and can't make it happen.
Old 01-19-2012, 08:07 AM
What kind of Weber is it? Webers aren't known for giving you good gas mileage...
Old 01-19-2012, 04:13 PM
bigcity25's Avatar
I believe its a 38mm, thinking that sounds right.
