Old 01-25-2012, 12:44 PM
PhatFJ PhatFJ is offline
Default H-55 into 1988 FJ-62
Quick question, any problems putting an h-55 5spd out of an 1984 FJ-60 into a 1988 FJ-62 with an auto in it now?
Thanks, Brian
KD0GEG
Old 01-25-2012, 12:59 PM
Besides the fact that you're going from an auto to a manual? I know a guy on the BOWAGWR this past summer had issues shifting into low range, can't remember the exact reason though.
What do you have planned Brian? You're asking about SAS on a 4runner, H55 into an FJ62..., you've got me curious
Old 01-25-2012, 01:14 PM
Just looking at different options for projects.
I think keeping the FJ-62 as an auto might be the best...
KD0GEG
Old 01-25-2012, 01:22 PM
Chris did that swap on his old FJ62. Seemed like a nice swap. My only gripe about 62's is that I would prefer a 5 speed manual. I'm guessing it's a straight bolt in. (?)
Old 01-25-2012, 04:42 PM
baja1d's Avatar
baja1d baja1d is offline
Logged in to post a very similar question myself. I apologize for a slight hijack. H55 mated to a 4 speed transfer case? Heard that the t/c lacks an oiling cup for 5th gear and that this set up is not possible? Have you guys heard of this?
Old 01-25-2012, 05:07 PM
The oiling cup spot is on the later t cases. IIRC 82 and beyond. My 85' 60 had it and every t case I've gotten as a spare has it.
I think the main PITA is the pedal bucket. other than that it is something you should have no trouble doing Brian. Lots of swaps on mud if you want to look there under the 60's section.
Old 01-25-2012, 05:26 PM
baja1d's Avatar
So just to clairify, an '86 4 speed transfer case shouldn't have any issues mating to a H55?
Old 01-25-2012, 05:37 PM
nope, none at all.
easy peasy. just get a shifter, oiler cup, and a shift knob.
It all bolts in. You may have to seal one hole in the t case that doesn't get a bolt through it with the swap, you'll see it when you get there. It's a 1/8 pipe tap and plug type of thing. super easy.
Old 01-25-2012, 07:15 PM
Thanks all!! I appreciate the info..
KD0GEG
Old 01-25-2012, 10:56 PM
baja1d's Avatar
Second that "Thank you" and again I apologize for the hijack.
