  #51
Old 08-26-2013, 12:47 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Anyone have a iPad RAM windshield mount I could borrow for the Ouray trip to test out?
  #52
Old 08-27-2013, 07:36 AM
mikeyhcrana's Avatar
Avenza PDF Maps is my favorite map/GPS app. You can put any PDF map in there and the iPhone will use GPS to show your location. Works great on MVUM's, and its really easy to find free topo/MVUM based on location.
http://www.avenza.com/pdf-maps
Oh and, best game is, Hill Climb Racing!
Mike KE0LNT
85 4Runner
TLCA#22551
  #53
Old 08-27-2013, 10:04 AM
I just got a free app called Vinny. It's a barcode scanner for vehicles- run it across the bar code in the windshield of any modern vehicle and it'll pull up its present value, a little history, kinda like a free carfax. With of course, the option to pay more for "more of the story," should it uncover something intriguing.
  #54
Old 08-27-2013, 12:07 PM
Don't start playing candy crush...
  #55
Old 08-28-2013, 03:09 PM
Inukshuk's Avatar
Ordered the RAM-B-166-TAB3U: RAM Suction Cup Twist Lock Mount with Tab-Tite Cradle for the Apple iPad. Will report back after Ouray.
  #56
Old 08-28-2013, 04:50 PM
CardinalFJ60's Avatar
Default ram mounts...i have the seat mount. pretty nice
curious how the windshield mount works and the visibility. I have this in my 60
RAM Mount Description:
RAM POD I universal No-Drill vehicle mount with non-locking cradle for the Apple iPad & iPad 2. The base of the mount clamps to your seat rail without any drilling necessary. Connected to the base is a 18" rigid flexible rod that can be bent to position your device to it's optimum viewing location. The RAM POD I will hold everything you need safely and securely.
Material:
High Strength Composite and Powder Coated Marine Grade Aluminum
Product Number:
RAM-B-316-1-AP8
  #57
Old 08-28-2013, 05:18 PM
Caribou Sandstorm's Avatar
I have the same one as you. Wiggles a little, need to secure it at mid extension, some how. I actually broke the retention part that you stretch to insert the ipad and remove it. I found just this part by it self for $20.00 on Amazon.
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
  #58
Old 09-06-2013, 04:35 PM
OilHammer's Avatar
OilHammer OilHammer is online now
I think your dash walrus has been gnawing on your steering wheel. Best to put him back in the ocean I think.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #59
LOL!!!!
  #60
Old 09-06-2013, 10:38 PM
Inukshuk's Avatar
Originally Posted by OilHammer View Post
dash walrus
Duh - its a CARDINAL
RAM mount in action. This model (RAM-B-166-TAB3U: RAM Suction Cup Twist Lock Mount with Tab-Tite Cradle for the Apple iPad, iPad 2, HP TouchPad) fits most tablets and iPads with cases. You can get all teh parts separately. The spring loaded holder is plenty secure. RAM has longer clamping arms and different ball mounts, so I could see using the longer arm and a ball mounted to the center console to have the iPad down low.
The ball is rubber coated metal. The clamping link is a plastic with a spring to open it as you loosen. The suction cup is solid. They make longer clamps and extension bars.
I imagine I will wedge a bit of towel or put some foam on the holder corners so it can be braced against the dash and windshield when offroad. Onroad the thing does not shake.
