Old 02-04-2012, 05:03 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default Replacing Hood struts
Has anyone replaced their hood struts on their 80?
If so, is there a trick to making it easier? Should I start with the part that attaches to the hood or start with the part that attaches to the truck sidewall?
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 02-04-2012, 05:07 PM
Start with propping the hood open!
Old 02-04-2012, 07:14 PM
Inukshuk's Avatar
Inukshuk Inukshuk is online now
I have, just changed hoods recently too.
12mm box end to crank off the parts at the hood and socket on the lower mount.
As UB said, prop the hood or get a helper.
Old 02-04-2012, 07:24 PM
cool breeze's Avatar
cool breeze cool breeze is offline
Curious how much did new struts run you?
Josh and Angelina
1994 FZJ80 2nd owner
Old 02-04-2012, 10:45 PM
davework davework is offline
I got a set on Ebay a few years back. They've worked great. I think hood and rear hatch were like $50 for all. Definitely worth doing instead of holding it up with the top of your head.
Old 02-05-2012, 12:10 AM
Inukshuk's Avatar
I have a used pair of struts of unknown strength for sale. I have for hood and for liftgate. From a 94. I do not know if they are original.
Liftgate struts OEM new were about $90.00 each at a super discount from one of our great suppliers.
Hoods were about $50.00 each at a super discount from one of our great suppliers.
For Sale locally with with full refund if they don't "hold up":
Liftgate Struts - $75
Hood Struts - $50
Old 02-06-2012, 12:03 AM
LETSROLL's Avatar
Thanks for the 12mm info.
Did it matter if you started with the end that connects to the hood first or the end that connects to the truck quarter panel? I assume there's a preferred way to do it, hence my question.
LETSROLL
TLCA#19430
Old 02-06-2012, 12:04 AM
LETSROLL's Avatar
New from Boulder Toyota $72 each. Something like $156 with tax
LETSROLL
TLCA#19430
Old 02-06-2012, 02:27 AM
I bought a set off Fleebay and they work great...Under $50 for the pair as I recall, maybe even under $25...
I'm not sure it matters which end you replace first - But in my case I popped the hood, put a set of vice grips on one strut while replacing the opposite strut. I connected up the end that attaches to the quarter panel area first, then the end on the hood. Took maybe 5 mins per side if that.
Best part, no more getting thunked on the head by the hood
Old 02-06-2012, 10:00 AM
Inukshuk's Avatar
Nope.
