Old 02-08-2012, 11:02 AM
Fishy's Avatar
Fishy Fishy is offline
Default DIY rack fairing?
I have a new Gamiviti Expo rack on my rig and I'd like to make a wind fairing for it instead of just buying one. The problem I'm having is finding a piece of plexiglass or lexan that is at least 50" long.
Home Depot sells 4'x3' (almost long enough) sheets for $80 but for that price, I can just buy the 50" Yakima one. Buying would be easier, but I'd like to make one if I can find the plexiglass in the right size. At least 50"x12" is what I'm looking for.
Any ideas?
Fish
Stan
UZJ100 (Non-White Edition)
OutdoorX4 Magazine Staff
100s in the Hills Co-Director
Old 02-08-2012, 11:06 AM
I have used these folks in the past for plastics. They can cut whatever you need. I usually get a rectangle of close to the right size then finish it with a jig saw.
Every 4th friday they have a remnant sale too....
http://www.coloradoplastics.com/
Old 02-08-2012, 11:15 AM
Another is Plasticare, closer to us on the southside.
http://www.plasticareinc.com/
Also check Craigslist, there's usually Yakima and Thule fairings that go for about $30 typically.
Old 02-08-2012, 02:13 PM
Stan I'd pick up a used fairing off CL.. you'd be hard pressed to DIY for under $50 when you factor in the mounting hardware. Even if you get a smaller one today, if you decide you want a bigger one later you could recycle all the mounts, and just swap out the plastic part with a larger piece of plastic. But the small one may be enough to knock down the wind noise anyway.
And to make all the Yakima stuff work, try a 1" section of sprinkler tubing, split lengthwise. Then snap the tubing over the bar, which quickly turns the 1" bar into a 1.125" bar.
Old 02-08-2012, 07:26 PM
Fishy's Avatar
I found exactly what I was looking for at Plastic Care Inc. Thanks Dave!
Picking up a piece of of 55x12 plexiglass tomorrow for $23. Hoping I can just cut it to shape with a Dremel Tool. Now I just have to fab some brackets....
Stan
Old 02-08-2012, 08:03 PM
Gerdo's Avatar
Gerdo Gerdo is offline
I usually go to Regal Plastics. Great prices and they are easy to work with.
I have made a few fairings but I use 1/4" ABS. I have had them on vehicles for 10 years or more with zero issues. still they clean up and look as good as the day I made them.
ABS is usually black, cuts great without chipping, sands great to soften the edges, flexes well to get a curve, has a textured side and a smooth side (I use the texture side out) and it's durable as anything.
2000 4Runner Sport, Lifted, 1/2 Locked, Winched, Some Armor, Fuel Tank Skidplate www.lilskipsoffroad.wordpress.com
Old 02-08-2012, 08:52 PM
Fishy's Avatar
I'll take a look at that tomorrow too. Thanks.
Stan
Old 02-08-2012, 09:50 PM
RockRunner's Avatar
X2 they are good people.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 02-09-2012, 08:04 AM
Beater's Avatar
Beater Beater is offline
you could do my favorite - an 80 running board cover cut to size.
john (johnny) henley
Old 02-09-2012, 08:10 AM
Plexiglass as in Acrylic? That won't hold up too well. The UV will yellow it, it will develop lots of small micro cracks which lead to a big crack. Lexan (polycarbonate) would hold up better is you want something clear. Black ABS would be the best.
