Old 02-20-2012, 10:36 PM
JadeRunner's Avatar
Cruise Moab Co-Chairman
Sorry to hear about your troubles. I haven't had those issues. I do remember having to replace my MAF sensor. Over oiling my oil filter really damaged it early on. Cleaning it wouldn't resolve code issues permanently. Can't remember if it was a PO171.
Good luck.
Scott Yoder KD0DHP
Old 02-20-2012, 11:14 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Originally Posted by Gerdo View Post
It definitely has to do with heat.
Today I packed snow on my crank position sensor and it definitely shortened the cranking time.
if what you say is true. Then start there. You need to get a DVOM and prob into the crank sensor and read the signal when cold. Then let it heat soak and read signal. Compare the two. If out of spec. Replace the sensor.
TLCA # 20314
Step by Step Bed Bob
Old 02-29-2012, 09:47 AM
Gerdo's Avatar
Gerdo Gerdo is offline
I replaced the fuel pump yesterday. I gave it a 5% chance of success. So far so good.
2000 4Runner Sport, Lifted, 1/2 Locked, Winched, Some Armor, Fuel Tank Skidplate www.lilskipsoffroad.wordpress.com
Old 02-29-2012, 09:52 AM
You may also need to clean your IAC unit on the bottom of your throttle body. (Idle Air Control).
KDěRCH
Old 02-29-2012, 10:44 AM
Were your fuel pressures off? Drop pressure when you shut the truck off? That is a lot of money to throw at a problem without knowing for sure.
Old 02-29-2012, 11:47 AM
TIMZTOY's Avatar
agreed
TLCA # 20314
Old 03-07-2012, 10:49 AM
Gerdo's Avatar
After a week or so all is good, it fires up instantly everytime!
