Old 04-27-2012, 08:33 AM
PhatFJ PhatFJ is offline
Originally Posted by nattybumppo View Post
Yes. Definitely go with the H55 shifter. Itwas expensive (newabout $155) but it works right, so it's worth it. The 4 speed shifter I re-used worked OK, but was really sloppyin some of the gears. Is that baby destined for your 40?
Good to know, where did you pick up your shifter? I do not know what this is going into, it may end up as part of another diesel conversion.. Thanks again for the info!!
KD0GEG
Old 04-29-2012, 08:55 AM
nattybumppo's Avatar
The shifter is a factory part. I can get the pn for you when I am back after cm12 if you want it. You should be able to order it at any of the local dealers with your RS discount, or from CDan of course, or John Hocker, who I use.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
