  #91
Old 01-01-2014, 11:31 PM
simps80's Avatar
simps80 simps80 is offline
I finally got the frame prep work all done, cleaned up, power washed.
I bought some rust converter stuff from eastwood that comes in a fogger bottle. So I'll be masking off EVERYTHING then fogging the inside of the frame. It doesn't need it, but I'll do that and some touch up chassis black while everything is torn down.
Pulled the steering box to get it re-sealed/rebuilt and to get at the insane amount of grease that's built up around the gear and mount.
This rental puller from Autozone was the bee's knees, I have a couple decent pullers but I needed every bit of this one to get the arm off..
I got the block back from Gunn its now ready to go.
Once I get the frame all finished up I'll start on the engine again.
making slow progress...I think the bulk of the expense is behind me now thank goodness
Mike | KØSMP |
  #92
Old 01-02-2014, 07:46 AM
treerootCO's Avatar
Very nice!
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #93
Old 01-02-2014, 09:57 AM
Wow Mike, this is looking soooo good. What prep was involved before dropping off at the powder coater? Your parts look amazing.
Just my.02 is that the expenses are still plenty moving forward!
  #94
Old 01-02-2014, 10:42 AM
simps80's Avatar
as far as prep goes...almost none.
I tried to clean them up as best I could ... I got the big chunks off
I probably would have saved some coin if I had done a better job. But I called the shop before hand and asked and they said its not a big deal if they aren't in great shape.
yea the expenses ... shakes head ... the expenses ...
Mike | KØSMP |
  #95
Old 01-02-2014, 12:12 PM
Kenon698's Avatar
Kenon698 Kenon698 is offline
Send a message via AIM to Kenon698
Fantastic Mike. Can't wait to see it. It should be one of the best 40's around. I am envious.
'79 FJ40
TLC # 15555
Ken Davidson
KDØGWP
"Moderation in all things including moderation"
  #96
Old 01-02-2014, 12:32 PM
Wow - that is some nice looking parts. Your 40 is going to look great.
  #97
Old 01-02-2014, 10:40 PM
simps80's Avatar
Mine will be sad to see its sibling leave
Thanks yours already is!
Mike | KØSMP |
  #98
Old 01-03-2014, 08:51 AM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Coming along very nicely! Can't wait to see this rig done.
  #99
Old 01-03-2014, 08:53 AM
Love it Mike! Great work!
  #100
Old 05-04-2014, 06:18 PM
simps80's Avatar
Default final engine work begins
i can't even remember all the iterations...
but I started final assembly of the engine today finally.
I got the chassis cleaned up good enough so that its relatively close to ready for the engine.
the engine's been sitting in the corner since final re-machining...
so I figured it needed a good washing. it did.
bought a set of these moroso brushes, there was a good variety of sizes and shapes. 12 brushes total pretty cheap from summit, enough variety to have one for every size orifice on the block.
I used warm water and simple green. Then brushed out every hole.
I used some micro fiber towels to wipe it down as I went, they didn't shred up and leave bits behind like the other rags or towels.
I knew it needed cleaning, but didn't realize how bad.
This was the 3rd go around and the water was still very dirty:
Once it was sufficiently clean, I sprayed it down with fresh water, then used compressed air to dry it out..every hole..again ...
once that was done, I used a thin coat of wd40 to prevent flash rust...
I wasn't sure how far I'd get.
ahh cleanness
Mike | KØSMP |
