  #121
Old 05-20-2014, 02:10 PM
treerootCO's Avatar
Event Coordinator
Use the new style pump and pickup
SOR:
Oem Oil Pan -
Fits 1958-8/87-Requires updated plug #034-43M & gasket #034-44M, order separately - YOUR OLD ONES WILL NOT FIT THE NEW OIL PAN
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #122
Old 05-20-2014, 04:29 PM
simps80's Avatar
simps80 simps80 is offline
Default engine assembly continued
yea it fits with new pump and THAT pan which is good cause that's the powder coated one
thanks for the replies
so that's all together now, up top is next
pics cause as usual I like them
Mike | KØSMP |
  #123
Old 05-21-2014, 09:49 PM
done yet?
  #124
Old 05-21-2014, 11:17 PM
simps80's Avatar
Originally Posted by nuclearlemon View Post
done yet?
Nope saving it for you.
I got another bolt in the pan..only 21 more.
Mike | KØSMP |
  #125
Old 05-22-2014, 08:33 AM
Snowrun's Avatar
Snowrun Snowrun is offline
Keep the pics coming. It is great to see the truck coming together.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
  #126
Old 05-22-2014, 10:08 AM
Pure awesome.
I assume it spins over nice?
KDØGWX
  #127
Old 05-22-2014, 01:03 PM
Lets go wheelin!
  #128
Old 05-23-2014, 05:24 PM
simps80's Avatar
Pure awesome.
it does. once all 6 were in i could still spin it by hand with the crank timing gear but it was more difficult, yet smooth. now i have to use the crank nut with a socket but its still smooth
Originally Posted by Rezarf View Post
Lets go wheelin!
indeed!
oh I've got all sorts of pics of various minutia..you just wait for the ridiculousness I take pictures of
Mike | KØSMP |
  #129
Old 05-23-2014, 05:28 PM
simps80's Avatar
so.. took today off from work..cause I hate it, but also cause I wanted to work on this engine a bit more.
I put all new shiny bolts in the oil pan..I'll be recycling mine back through the plater to return to the generous donor of the new hardware whom I sure none of you could guess the identity.
I looked for some data for torque specs for a while so i'll put these here
the pan calls for 84 inch pounds
the timing cover calls for 43 inch pounds for the small ones and 18 lb/fts for the 2 14mm bolts.
I don't have a torque wrench that reliably goes that low
so when I was at Auto Zone they had a free in/lb 3/8" drive rental .. it was handy and free so why not
Mike | KØSMP |
  #130
Old 05-23-2014, 05:34 PM
simps80's Avatar
I am really impressed with toyota's gasket kit.
I have 3 total sets of gasket kits now including 2 different non-oem and then toyota's.
Its not even close on quality. Even down to the packaging, Nicely boxed and organized, Toyota even bubble wraps the all-important head gasket.
So I put that on after filing down the little locating ferrules since the head and block were decked, and the ferrules wre a little rough from removal.
Once the head was on, I figured better paint this deal before I get too much farther.
so...I made a paper mache valve cover to approximate what should and should not be painted on the head, then taped over the powder coated timing gear and oil pan.
then taped over mating surface for manifols and trimmed tape to match profile.
then taped over side cover opening.
i was going to leave the freeze plugs silver but I got tired of taping
ok its not paper mache. lol. reading test... moving on.
Mike | KØSMP |
