  #171
Old 08-03-2014, 10:23 PM
simps80's Avatar
simps80 simps80 is offline
Yea injury number 3 was because I tried to play golf and knew I shouldn't cause it was too soon after injury number 2.
I was "protecting" my left side swinging weird and tore a muscle on the right...
I am realizing I am getting too old to treat my body the way I did in my twenties..
Strengthening my core and losing weight is my focus now.
But I am determined to get as close as I can to driving this to the rally..
I will have to check into that motorcycle belt.
Mike | KØSMP |
  #172
Old 08-06-2014, 02:34 PM
done yet?
done yet?
done yet?
  #173
Old 08-06-2014, 03:31 PM
treerootCO's Avatar
Event Coordinator
actively working on it now....
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #174
Old 08-07-2014, 10:51 AM
simps80's Avatar
Put flywheel in torqued to 58 ft-lbs with blue loctite pushed tabs up on lock plates.
Then went about the business of figuring out the throwout bearing. I used this old piston pin from a mack e6 which was exact diameter and tapped the collar out from old bearing.
Then used the old bearing to press the new one onto collar.
The next day I called in the air support.
Mike and john came over to lend me some massive help.
Started by inspecting the internals of the tcase and transmission then put new gaskets and front seal in.
Ignore the exxon oil slick..lol
Mike | KØSMP |
  #175
Old 08-07-2014, 11:03 AM
simps80's Avatar
Next up went clutch disc and cover.
Sprayed down flywheel and clutch with brake clean then bolted it in with fresh toyota 8mm bolts torqued to 16 ft lbs. Very slowly torqued one by one in even sequence.
Somehow missed the pics of that.
Next we slid this mess together and with the other two that went much smoother than I imagined it. Torqued the trans to bell fresh bolts to 62 ft lbs evenly.
After that it was time to finally put it in the truck..
The truck was pretty high up on jack stands so we left the back up and dropped the front down which really helped with the angles. Used some ratchet straps for safeties under the engine..then once it cleared the front diff we dropped it down slowly and brought trans up with floor jack. It swung into place with minimal trouble. It was very helpful to have 3 sets of eyes and hands!!
At the stopping point last night we had this! !
Again huge thanks to Mike and John..big times
Mike | KØSMP |
  #176
Old 08-07-2014, 12:29 PM
OMG, that's awesome!
WØREK
  #177
Old 08-07-2014, 01:28 PM
subzali subzali is online now
x2, so exciting!
  #178
Old 08-09-2014, 02:50 PM
Lots easier without the fenders
  #179
Old 08-10-2014, 12:31 AM
Disappointing
Super cool. You're going to have a dream FJ40!
Originally Posted by nakman
  #180
Old 08-13-2014, 08:44 PM
simps80's Avatar
Thanks everyone for the encouragement and nice words.
Made some more random progress.
Took apart the inside to clean out the tank..
The inside of the tank was perfect despite the old gas in there.
The outside of the tank had some surface rust corresponding to the felt spacers.
The floor pan had some surface rust underneath the felt too.
Cleaned both up then used rust converter then sparingly covered in a quality epoxy.
The history lesson on the floor pan was interesting..
This Wyoming rancher liked poker, cigarettes, and beer..good trifecta.. Lots of old pull tab can tops and some miller bottle caps and several matchbooks from some laramie "points of interest" were found.
Meanwhile there has been an ongoing war between me and the egr system.
I had a couple egr sets i have been acquiring. So I have been using components of each to try to make one usable. I needed the manifold pipe off this one but after a week of heat rust penetrant wax a 4 foot cheater a new expensive wrench and lots of fruitless effort..
Mike came over and assessed that the shock was being lost by the movement of the wood bench mounted vise.
We took it out front and parked a tire on it and eventually the 4 foot cheater and new 1 7/16 wrench (36mm wrench not available quickly) got it loose.
Mike | KØSMP |
