  #41
Old 03-12-2012, 08:32 AM
Originally Posted by simps80 View Post
so tempting to go full blown OCD with this thing and start taking it all apart and powder coating everything and painting bolts and craziness... don't want to do that; want to get it going and drive it.
It's such a clean rig, I can understand what you mean.
I only need an air pump and air rail.
right ?
I believe so. I think I have both for a '77 2F if you need them. At a minimum, I would try to get it to pass without all the other stuff first before you go through the hassle of trying to re-smog it.
  #42
Old 03-12-2012, 08:39 AM
treerootCO's Avatar
Event Coordinator
Originally Posted by MDH33 View Post
...I think I have both for a '77 2F if you need them. At a minimum, I would try to get it to pass without all the other stuff first before you go through the hassle of trying to re-smog it.
1976 missed the Ritter cutoff for collectors plates by one year Because of that, he needs to pass emissions every two years. I am hoping the 76 doesn't need an EGR but I would put the catalytic converter, smog pump, air rails, and the VSV stuff on it.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #43
Old 03-12-2012, 08:50 AM
Does it already have a catalytic convertor on it? If so, the other stuff will be easy. Also, based on that other thread about the '77 with headers, it sounded like they passed with just the air rail and pump.
I'm bummed about the collector plates too. My '80 hilux needs to pass every two years also.
  #44
Old 03-12-2012, 09:05 AM
76 didn't have a cat. doesn't mean you can't run one to be cleaner.
I bet you would be fine with an air rail and pump.
WØREK
  #45
Old 03-12-2012, 10:08 AM
Yea - not cats on the '76. Mine passed 5 years ago with a functional EGR and no air pump, but it required carb and timing adjustments (that I can't remember the details on any more....).
  #46
Old 03-12-2012, 10:40 AM
I wouldn't take it apart. Clean it up and enjoy driving it. Seen too many rigs get taken apart and then never get put back together again.
  #47
Old 03-12-2012, 11:00 AM
Agree 100%. Let us know when you're going to drop in the 2F. I would be happy to lend a hand. You're going to love having it on the road/trail.
  #48
Old 03-12-2012, 11:23 AM
treerootCO's Avatar
Event Coordinator
Does it already have a catalytic convertor on it?...
Yea - not cats on the '76....
I was thinking '76 was the first year based off of the 6,000 GVW and higher specs that dd not require them in '76. Looks like Toyota ran them from 1/79-1984. Cool, so no cats
1/75-12/78 FJ40
Exhaust manifold flange
www.root45.com
TLCA #14133
  #49
Old 03-20-2012, 03:37 PM
Sweet! Nice find!
My Kalifornia 1976 came with EGR, but I am told that federal didn't get them until 1978. The head dude at Colorado AIR who tested my 1978 FJ45 told me flat out that we don't need EGR up here on the old iron because combustion temps don't get high enough to make much NxOx. You do need the smog pump though. It doesn't need to work, just look like it's working. I had mine mounted but disconnected for about 15 years and she always passed every year. Just before the test I would throw the belt on, then take it back off after it passed.
  #50
Old 03-20-2012, 03:50 PM
Sweet! Nice find!
According to SOR, California EGR started in 9/'73 ('74 model year), and Federal EGR started in 1/75 (late '75 model year?). My Federal '77 has it...
