  #71
Old 04-16-2012, 12:16 PM
The idle circuit should allow the bike to start even with the needle down low. How many turns from closed is the idle fuel screw?
Did you try starting it cold with the choke on?
  #72
Old 04-16-2012, 01:52 PM
Yes choke on, bike does not start otherwise. I will check the idle fuel screw tonight, that's the new red one on the bottom right? the plastic black one is just idle adjustment?
  #73
Old 04-16-2012, 09:01 PM
Fuel screw was about 2 turns out, I put it back to 1.5. Will do my best to ride to work on Thursday and see if I can notice a difference.
  #74
Old 04-17-2012, 08:30 AM
If you turn the fuel screw in until you get some popping when decellerating in gear, you have leaned out the idle circuit. If you can run the fuel screw nearly closed and the bike still idles without decel popping, then the idle circuit is running too rich for some reason.
Here is a nice summary on Keihin carbs. It's written for a different model but is very similar to the FCR.
http://www.gadgetjq.com/keihin_carb.htm
I like this graphic. I helps isolate the parts of the carb to different throttle positions.
  #75
Old 04-17-2012, 10:15 AM
Yeah that graph is helpful, thanks. So maybe I would have been alright on slot#3 then, if I had spent more time with the idle fuel screw? huh.
  #76
Old 04-17-2012, 10:49 AM
What I don't get is why the needle position affects starting at all. That why I think something else isn't right.
  #77
Old 04-17-2012, 11:26 AM
I called JD just for fun.. they suggested routing my float bowl overflow tube up and over the carb, just to make any gas travel uphill before it can escape. Maybe I need to create a little back pressure there and gas is escaping out the tube that I just don't know about. the other suggestions was pull the carb and lower the floats, even if they measured in spec, make them lower. But in their opinion, there's nothing in their jetting that would account for such an increase in gas consumption.
  #78
Old 04-17-2012, 11:58 AM
Does the tube from your gas cap to the frame have a check valve in it? You might try venting the tank to atmosphere to be sure that tank pressure isn't pushing fuel past the float valve. Also try the fuel screw thing to confirm that you can create a lean idle with decel popping.
  #79
Old 04-19-2012, 12:19 PM
Success? Rode to work today and I must say the bike's running as well as, or possibly better than, ever. Starts, idles, quickly jumps in RPM, and a slight amount of deceleration popping, all feels right. What's curious is I've learned that the ease of shifting has everything to do with how well the bike is running. I can find Neutral fairly easy now from 1st or 2nd, even while at a complete stop. When the bike runs poorly, it'll do anything from die when I shift into 1st, to just about refuse to go into Neutral either stopped or moving.. so for whatever reason, neutral shifting has become my litmus test.
Ok onto a question: I flipped the float bowl drain line up and over the carb, as directed by JD. while doing so, I realized that I do have some gas in the line that exits the top of the carb, on the other side (near where the throttle cables attach). Is this normal? or am I onto something here... the arrow points to where the gas was this morning when I rolled the bike out of the garage, first time I've touched the bike since Sunday.
  #80
Old 04-20-2012, 08:54 PM
The tube with the arrow is one of the vents higher up on the carb. I think it's hard to get gas in that tube UNLESS the bike is layed over on that side. I've noticed a bit of gas in there when picking my bike up. It also seems to evaporate very slowly.
The bowl drain tube looped over the carb - any gas in it? That's the one that's more important. Fuel will drip out of that one, without tipping the bike, if the level in the bowl is too high.
