Old 07-14-2006, 12:28 AM
Default stainless steel brake hoses?
So I got some of these to replace my sketchy-looking I believe OEM brake hoses, and found that they are all long. I was warned about this, and the axle to wheel hoses aren't bad, I'm fine with them, but the body to front axle hose, which was 7" stock, is 16" long . The OEM body to rear axle hose is 14" with the stainless one being 16" so I'm sure that one will be okay, but even though it's an aftermarket kit I would think that the front would be kinda close ? Anybody else install stainless steel hoses (I got these from SOR) and run into the same problem? I horseshoed mine over by the diff to keep it away from the tire, but I'm going to call those guys tomorrow and try to get the skinny on it.
Old 07-14-2006, 12:59 AM
i've got stainless on mine...picked them up at aai speed shop.
Old 07-14-2006, 05:07 AM
Longer is good! You have and will be modifing your suspension and gaining both wheel travel and distance between axle and frame, longer is better than pulled apart! If you have issues of the line getting to close to the tire or hanging down try some rearangement of the steel lines or you can also get creative with springs just make sure you account for wear of the spring on the brake hose! The front one does sound excessively long however as 9" longer than stock is wishfull thinking as far as wheel travel goes!
NOTE; AAI (what Ige referanced) is a great shop and they can make up any custom length you need if they don't have it in stock!
Old 07-14-2006, 06:38 AM
PabloCruise's Avatar
I used factory (rubber) hoses when I put my lift on - used a rear line for the front and it ran in a spiral - want a pic?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 07-14-2006, 07:45 AM
Sure TJ, I'll take a pic of mine once I get my camera from Golden this weekend too and see if anybody else would be worried about it.
Old 07-16-2006, 07:41 PM
So does anybody think this will be an issue? It's above the diff, I *think* far enough away from the pinion not to be a problem, but
Old 07-18-2006, 03:15 PM
IanB's Avatar
IanB IanB is offline
Make a small loop and secure it to itself with a plastic quick tie to take up the slack.
1976 FJ-40
2001 UZJ-100
Old 07-18-2006, 03:17 PM
IanB's Avatar
Based on the fact you have 9 inches of slack the loop should be 3 inches or less in diameter (circumference divided by pi).
1976 FJ-40
2001 UZJ-100
Old 07-18-2006, 04:06 PM
Yeah, I was going to suggest what Ian said (without the math). Twist a loop in it then put a zip tie around it. You've already got it bled, should be able to do with it already installed.
Oh, and on the run this weekend make sure I'm behind you.
Old 07-19-2006, 07:27 AM
Actually I didn't have them bled yet, so it was easier to put the loop in it . And don't worry Tim, my truck now stops faster than ever since I got my two last rear wheel cylinders (that were frozen) spinning and basically adjusted so it's tight. My handbrake still doesn't work the way I think it's supposed to, so I'll have to investigate that further. Anyway here's current pics:
