Old 03-24-2012, 11:35 PM
bomber22's Avatar
bomber22 bomber22 is offline
Default oil changes
how many of you think that your oil need's to be changed every 3- 6 thousand miles ? mabye every 10.and where do you dump the old oil?
Old 03-25-2012, 08:16 AM
I change the oil about 3K and they have waste oil tanks at O'Reilly's stores. Don't pour brake fluid or anti-freeze in them, just engine and gear oil.
Old 03-25-2012, 08:36 AM
Usually after 3k, but that sometimes goes longer.. more like 4 or 5k. Sometimes I do it earlier if I have been hard on the motor like on a moab trip. I usually take it to orieleys too.
Old 03-25-2012, 08:38 AM
I go 4k to 5k on the 80 and take the dregs to O'reilly's as well.
What is an acceptable way to get rid of used brake fluid? I've got several bottles of waste.
Old 03-25-2012, 08:39 AM
4-5k. I have my local quick lube do it. Or when I do it myself, I take it to them to dispose off. I have one of these that I use to transport the used oil.
Old 03-25-2012, 08:44 AM
Same here
I think I took mine to the hazardous waste recycler in Boulder.
Old 03-25-2012, 08:54 AM
bomber22's Avatar
looks like 3-5k is pretty standard. the o'reillys at 88th and wads will take yhe used oil but their tank is always full, or so they say. i believe walmarts take used oil to , might have to check that out.
Old 03-25-2012, 08:55 AM
Romer Romer is offline
I run synthetic and do it once a year. I take the old oil to Walmart. Plenty of tests show you can go longer than a year on the synthetic, but that feels about right to me. Thats about 8-9K miles
Old 03-25-2012, 09:14 AM
3k is a waste of money IMHO. esp at 8 qt's a pop. Most of my stuff is 5-7500 min
Old 03-25-2012, 09:16 AM
5000 miles with Mobil 1 in my Tundra and 2009 Corolla.
3000 miles or every year or two with dino oil in my FJ40
O'Reilly, Walmart supercenters, Carquest and Autozone have all taken oil from me in the past.
