  #81
Old 10-07-2012, 10:58 PM
any reason to get a 525exc over a 450 other than 75cc?
  #82
Old 10-08-2012, 12:08 AM
Nope, it's the same bike. Except for the bigger motor. It's a bigger bore cylinder with the same stroke as the 450. From outside they are identical except for the plastic that says 525. Same weight, same chassis.
Mo powa.
  #83
Old 10-08-2012, 08:12 AM
More power, same weight
  #84
Old 10-08-2012, 10:23 AM
They ride a little differently. The 450 likes to rev up a little more before it's in its happy place.. while the 525 a little more tolerant of low RPM chugging. I would even say the 450 is a bit snappier in the power band area, compared to more linear predictability of the 525. Think of it as a continuum, where your 250 is at one end and the 525 is at the other, you can pretty much plot the 450 about 2/3 the way between them, closer to the 525.
Also the 525 is a little bit quieter than the 450. Those were my takeaways from riding both versions within in the club here.
  #85
Old 10-16-2012, 05:23 PM
The Aloha Skateboards PBR sticker is worth at least $100... http://denver.craigslist.org/mcy/3317600157.html
  #86
Old 10-31-2012, 12:34 PM
Jenny Cruiser's Avatar
Default 2001 Africa Twin
You don't see these very often. Want's some money for it though.
http://cgi.ebay.com/ebaymotors/Honda...item3ccbfeae7c
  #87
Old 11-05-2012, 03:23 PM
Here you go http://denver.craigslist.org/mcy/3386049465.html
  #88
Old 11-08-2012, 12:07 PM
Might be a good deal here:
http://fortcollins.craigslist.org/bar/3393579965.html
  #89
Old 11-11-2012, 02:04 PM
I was close but between keeping the wife happy with new carpet, one dog eating ibuprofen and the other with some sort of increased calcium issue I have to put off the 2 wheel fun for a while longer
  #90
Old 11-12-2012, 09:53 AM
...I have to put off the 2 wheel fun for a while longer
Just be ready soon after Cruise Moab
