Old 04-10-2012, 04:02 PM
Default CEL P0300 with pics.
So, Driving to work today there is a slight stumble, and an orange picture of a 4.7l V8 engine on my dash and the word CHECK below it.
Old 04-10-2012, 04:05 PM
I finished work and drove the 1.5 miles home slowly. Joined my wife for an adventure to Wall-Mart to buy a $79 ODBII tool. Already had a shop manual, Already had a spare COIL in tool bag.
Old 04-10-2012, 04:11 PM
Removed negative terminal on battery. Removed Air intake, removed offending coil, replaced with new OEM coil. Gently cleaned around throttle body with paper towel. Replace air intake and battery and No more V8 pic on the dash. Tools needed:
Pair of pliers
10mm box wrench
10mm socket and extension
ODBII Scanner. (I now own)
Old 04-10-2012, 04:25 PM
I like the relatively easy fixes
Old 04-10-2012, 04:31 PM
I like when it takes longer to do a write up than the repair. The key to the simplicity of this was the ODBII scanner. Having the right tools can make all the difference in the world.
Old 04-10-2012, 05:02 PM
I thought you just replaced them one at a time til the light goes out
Old 04-10-2012, 07:10 PM
waggoner5's Avatar
Thats cool. We had the same thing happen on my truck at Pismo. 5 min later, we were back in line at the poker run. Love the easy ones.
Old 04-10-2012, 07:31 PM
I noticed something odd. Spot the difference?
Old 04-11-2012, 06:14 AM
2 4's and no 7! i'm good at these
Old 04-12-2012, 11:25 AM
bomber22's Avatar
bomber22 bomber22 is offline
4 is 5 ,5 is 7 or or like stated above 2 4's and no 7's
