Old 04-13-2012, 09:20 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Originally Posted by farnhamstj View Post
Removed negative terminal on battery. Removed Air intake, removed offending coil, replaced with new OEM coil. Gently cleaned around throttle body with paper towel. Replace air intake and battery and No more V8 pic on the dash. Tools needed:
Pair of pliers
10mm box wrench
10mm socket and extension
ODBII Scanner. (I now own)
you should have said somthing.. i have 8 spare coils
TLCA # 20314
Step by Step Bed Bob
Old 04-14-2012, 09:17 AM
Thanks for the offer. I already had a spare in my tool bag.
Old 04-14-2012, 09:40 PM
The scanner is a must have tool IMO. It was probably the first new tool I got after purchasing the 80. I now keep one in the wife's Subaru too. Nothing is worse than owning one but not having it with you.
Happy to see an easy fix.
