Old 04-14-2012, 09:56 PM
baja1d's Avatar
baja1d baja1d is offline
Default 2F Carb linkage
Having issues figuring out the carb linkage for my motor swap. Converting from the '64 1F to a '86 2F from a 60. Minus the gas pedal from the 60 I have all of the OEM linkage but it appears that I'll have to modify it. Before I start cutting and fabricating a bracket that has a 50/50 chance of working I'd like to see what others have done or how their rig is set up. Please post some pictures of your carb linkage on your firewall. Here's mine for reference:
Travis Hurley– Owner/ C.E.O.
Old 04-15-2012, 09:40 AM
kurtnkegger's Avatar
Matt has a bunch of pictures on his thread http://risingsun4x4club.org/forum2/s...ad.php?t=16462 You might have to change your bracket to accomodate the new carb...
Old 04-15-2012, 10:50 AM
baja1d's Avatar
Thanks, the pictures definitley helped give me an idea of which bracket to fab/modify
