Old 04-14-2012, 10:15 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default P0305 Code
Anyone have any experience with this code? I believe it's a misfire on the #5 cylinder.
I've been having rough start/hesitation issues for a few months now. I replaced the plugs, wires, cap/rotor, air intake hose, etc., and even ran a can of BG44 through the gas tank.
This code popped for the first time today. I'm thinking fuel injector?
Thanks John
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 04-15-2012, 08:47 AM
What kind of engine? I had P0306 earlier in the week. Misfire in 6. 1 ignition coil later, fixed.
Old 04-16-2012, 12:35 AM
LETSROLL's Avatar
My bad. Its on my 1996 FZJ80
LETSROLL
TLCA#19430
Old 04-17-2012, 01:02 AM
Colorado80 Colorado80 is offline
Checked the injector resistance? I am trying to track down my P0301 right now as well.
1996 LX450
Old 04-17-2012, 07:53 AM
powderpig's Avatar
So Injector failure is fairly rare on the 80, but does happen. You can take a stethoscope with long sound pick up and listen. It really is hard to get one of the noid's into most of the injector areas to see if the electrical impluse is working from the computer.
Did the BG 44 doing anything? If so, then I would guess a injector. Have you looked over your wiring harness to see if you have any wear spots as well.
Most of my misfires have been either the spark plug wires, spark plugs them selfs, or the install(biggest %) where the spark plug wire is not seated fully on either the spark plugs or in the cap.
You said you stated this was happening before you changed the wires, cap and rotor. Did you happen to check out the distributor as well. Is the rotor turning fully with out wobble? Have you check out the Coil, stranger things have happened where the coil is not functioning fully and creating a misfire on only one cylinder. Just some long shots, then last but not least, is the computer not working properly and since this is a sequencial fire engine, instead of batch fire. The computer could be not giving the proper voltage.
If you have a FSM, follow the procedures in it to determine what the problem is. I can loan you a manual if you need one.
Old 04-17-2012, 12:00 PM
MountainGoat's Avatar
Club Treasurer
For another data point, my P0301 was resolved by a valve adjustment. This was on my 95 FZJ80 at approximately 230K miles.
Dan Kucera
TLCA# 17536
KDWJO
95 FZJ80 LC Red
99 UZJ100 LC Black
