Old 04-17-2012, 07:12 PM
OTOH, maybe you're right you should just go orange. I think the spare part/tech resource benefit is a valid one.
http://rockies.craigslist.org/mcy/2949511048.html silverthorne
http://westslope.craigslist.org/mcy/2957907960.html GJ
Old 04-17-2012, 07:55 PM
If you can spend the $$. get a KTM. Some value to shared parts and knowledge with your friends. There are good deals, but you jump to the $4k to play. Get a 450-530 EXC also known as XC-w 03-07 I think this is what most of us have. Motor is called the RFS (racing four stroke) These bikes could be thought of as the 80series with factory lockers of KTM trail/desert Motorcycles. Stock tanks are about 9.5liters, 13 and 26 are also available.
My take on used KTM
Look for play in rear wheel bearings. $90
Look at the amount of wear on the clutch cover and stator cover. $100 per side
How scratched bent does the plastic look. Is it original? $150 will buy all new
Bent sidewalls on rims. $150 and 4 hours of your time
Has top been rebuild? Typical at 7k-10k miles on engine. $800 and 10 hours or $2200
Upper and lower shock mounts are bearings not bushings. $150 set
Ask owner how often oil is changed and what they use. For this kind of bike expect to hear 10 hours or 300 miles. Motorex is $14 a QT, Rotella is $14 a gallon.
Leak at the water pump (small drain hole) is not uncommon. $10 4hours
Oil leak at counter sprocket is o- ring and maybe spacer or Sprocket. $25
Bent radiators. $25-$300 per sider rebuild vs replace
Chain and sprockets last about a season and a half. $155 for a full set
Extras that add "value"-- in no particular order prices are retail guess. Figure 1/4 value on resell or buying used
Radiator guards-Aluminum $100
Skid Plate $90
Bark Busters $90
Scotts steering damper $400
Fork Breathers $40
JD ket kit $80
Reklus clutch $500
Street legal $500
New tires (to me this means they are still spending money on upkeep of the bike) $120
Old 04-17-2012, 08:01 PM
Those bikes that Nak posted both look good to me. Though not street legal. Some hoop jumping involved.
Old 04-17-2012, 08:27 PM
This one could be good
http://denver.craigslist.org/mcy/2958054728.html
I like that it has a title. That could make it much easier to plate. For frame of reference My 2007 has 8,000 miles.
Old 04-17-2012, 10:24 PM
that Grand Junction one looks worth the pain to register, IMO. Though I'd like to check out the guy's house in Silverthorne, he's got quite the view.
Old 04-18-2012, 12:02 AM
that's just like mine!!
Old 04-18-2012, 12:30 AM
RockRunner's Avatar
That GJ bike is worth the drive. Between that one and a newer WR you would have a great start to a dual purpose bike. One thing I have noticed is that the Orange parts are more expensive. You can't go wrong with either as long as they have the "magic" button.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 04-18-2012, 10:49 AM
No pics doesn't give me a warm fuzzy, but it's close enough to check out anyway? http://denver.craigslist.org/mcy/2927872029.html
Old 04-19-2012, 10:48 AM
Caribou Sandstorm's Avatar
That WR has some potential, but there's some peer pressure around here to go Orange.....
On a side note - my favorite 2 quotes, which seem to exist in all motorcycle ads, is "low hours" and "extras."
"Low Hours" - What exactly are the Hours thresholds that all riders except me seem to know? Of course in most cases the bike in question is below this threshold....
"Extras" - Translation is that I'll have to spend lots of time unraveling the PO's hacks....
I am a yamaha guy, so if you get a yamaha, you won't be the only blue guy for long....
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 04-19-2012, 12:30 PM
I think Gunnison could be considered on the way to Moab... plus you'd have the same ride as Subzali http://denver.craigslist.org/mcy/2965953789.html
