Old 05-09-2012, 03:51 PM
Default Adding receiver hitch to popup camper for motorcycle hauling
Thread title pretty much says it all.. the wheels are turning regarding adding a receiver hitch to my camper. It's a 2006 Coleman Santa Fe... so not exactly Jayco Baja or Fleetwood E-2 in terms of frame size. The frame is 2 pieces of 2x3 rectangle, probably .125" in thickness, running lengthwise about 5' apart. Between the frame rails is some C-channel stretched across every 4' or so, probably helps keep the frame from twisting, supports the plywood above it, then not much else.
The existing back bumper isn't much stouter - another C channel, 3" tall, feels like .080" thick but it may be .100" on a good day with a dirty caliper. It's obviously not a part of the long-term solution.
My biggest worry is I create something that totally supports the bike, but just rips apart the rest of the camper frame. Though I'm trying to picture a catastrophic failure and maybe it's nbd.. I will post some pictures later, but curious if anyone's done this?
Old 05-09-2012, 03:55 PM
Didn't Red Chili say that he added a receiver to his popup? In the diesel thread? I think he did so he might be a good source for info although I'm not sure what the difference is in structure between a Coleman and a Starcraft camper...
Old 05-09-2012, 04:03 PM
Yeah I saw that, thanks Jeff... what are you doing over here, anyway?
difference is his Starcraft is more like a Cruiser frame. The Coleman is more like a HF utility trailer.
Old 05-09-2012, 04:07 PM
Daydreaming
Old 05-09-2012, 04:37 PM
Bad idea Nak. You will develop a sway that will terrify you. The whole thing will become ungodly unstable.
DAMHIK ...
Even a bike rack exposed some impending sway due to a large drop ball mount in my case. I got quite an education!
You can cut and lengthen your frame and create a rail mount...
KDěRCH
Old 05-09-2012, 04:44 PM
I was going to say you will not have enough tongue weight with motorcycles on it and you'll get ridiculous sway that could cause a serious accident. you would need to cut and add a deck. Even so you still need to figure out if you will have enough tongue weight without it being too much and out of balance. You'd probably be better off finding a camper with a deck on it, JMHO.
WěREK
Old 05-09-2012, 04:48 PM
I already added a rail mount up front for Gavin's bike. seems like with that, and a second propane, I keep adding tongue weight. I could see shifting the small bike to the back, then the big bike up front, but still feel I have more tongue weight than anything.
I've also got a receiver tray that could be used to move some concrete around, for testing purposes..
Old 05-09-2012, 04:50 PM
Here's a thought... take the box off the frame... build a proper tube or box frame of your desired length... with deck... and place a heavier duty axle and leaves under it after determining oh, say, 60/40 front-rear load bias, laden. Just temp mount the axle till you have the sweet spot nailed.
And there you have it. Nakspedition style.
KDěRCH
Old 05-09-2012, 04:57 PM
I have considered that, really. I get the 60/40 split on load ahead of the axle, but there's a hard limit on tongue weight of say, 500 pounds? Which includes everything else up there. I think 2 guys should be able to lift the trailer off the ball...
I find it curious though how much these types of toy haulers vary. Here's one with the camper in front of both axles. How is that even maintaining close to 60/40 with and without 3 ATV's?
http://denver.craigslist.org/rvs/3001371439.html
Here's the other extreme: no tongue weight at all until you add the bikes:
http://denver.craigslist.org/rvs/2996807292.html
maybe 2 axles allows you more flexibility there.
Old 05-09-2012, 05:00 PM
even with the big bike in the rear and the small bike in the front and a propane can I think it'd be sketchy. you can measure the tongue weight fairly easily. You don't want too much or too little is all, although too little usually bites you first.
WěREK
