Old 05-16-2012, 11:01 AM
treerootCO's Avatar
Event Coordinator
Most ignition switches go out because you have too much weight on the keychain. Are you sporting one of those janitor/building maintenance key sets?
You already hot wired it and it started so the coil is getting 12volts. Try turning the key as slowly as possible to see if that works. Be careful not to over turn the key because it can go past the contacts. Good workaround until you tear it apart or replace it.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 05-16-2012, 11:07 AM
Thanks Mike-
I just tore it down. Its such a simple device, there is defiantly some wear on the contacts on both side of the switch. I can't tell if its enough to not allow them to connect, I cleaned up the contacts with a scotch-brite pad and a smear of dielectric grease. reassembled and nothing.
I am only getting like 6.xxx volts to the switch
Old 05-16-2012, 12:56 PM
That does not seem right. Have you checked at the fuse box to see if 12 volts is making it that far? Might be time to clean the fuse holders and get them back to nice and shiny.
Old 05-16-2012, 09:21 PM
AHorseThief's Avatar
If the fuse block cleaning doesn't do it, it's time to check the wire back to the switch. I was having the same problem intermittently and the solution in my case was to replace the corroded wire section in the engine bay that feeds the ignition switch.
The fun of 40 year old, hacked into wiring
Nick Kimball
'73 FJ40 Rockin a 327 SBC
Old 05-17-2012, 10:07 AM
Thanks, my wiring is still stock, I am the 2nd owner. That is nice for this kind of stuff as all my manuals still line up with whats under the hood
Old 05-17-2012, 10:53 PM
Jacket saved the day, ignition switch replaced, she fired right up.
Old 05-17-2012, 10:55 PM
Old 05-18-2012, 10:56 AM
Brag, brag, brag.
Glad you got it fixed. Nothing more frustrating than click when it should go vroom.
Nick Kimball
