Old 06-07-2012, 07:52 PM
Beachboy Beachboy is online now
Red Chili,
Where did you have it done?
Old 06-08-2012, 12:25 AM
Squishy!'s Avatar
Squishy! Squishy! is offline
I think he has a modified Front Range Off-Road kit he installed I think I helped him with it...
-Justin Morgan,
TLCA #23166
"Apollo"-1988 Hilux, 1999 3.4L, Supercharged, 2.1" URD pulley, URD 7th injector, 2 1/2" Magnaflow exhaust, SOLD
"RedChili"-1987 Super Beast
Old 06-08-2012, 12:26 PM
Yup. Like he said. Front Range Off Road.
It came in handy when I shredded a pinion on Wipe Out Hill (damage was done on Cliffhanger the prior day). Somehow I always thought I might flat tow some day, and the lockouts are stronger (Bobby Longificated) than a flange and definitely more so than the stock semi-floaters.
TO DO LIST: 3.4L, Supercharged, 2.1" URD pulley, 2 1/2"-3" Magnaflow exhaust, SAS, Duals.
You better fuel that baby better than the red runner you had that ate itself!!
Duals??
KDěRCH
  #24
Old 06-08-2012, 01:46 PM
Squishy!'s Avatar
? I got like 18-20 mpg when I wanted
Duals??
T-cases
-Justin Morgan,
TLCA #23166
  #25
Old 06-08-2012, 02:03 PM
Originally Posted by Beachboy View Post
As for the law, as one person said, if the truck has the capacity to tow you do not need the braking system. Wrong, if you pull a trailer within the truck limits, many trailers has brake systems on them, there is a reason. Check the state law.
I should have been more specific. With-in the un-braked tow limits. I don't recall what it is for a F250 but the Chili could be under that.
  #26
Old 06-08-2012, 03:50 PM
OilHammer's Avatar
I would caution anyone planning on flat towing out here. I used to tow my 40 from NC to Tellico every year. I was using a 2003 Ford explorer with a v8 and tow package. The tow bar needs to angle slightly down towards the towing vehicle. Stab your brakes at speed and what happens? The rear end raises up! If the tow bar angles up, and you try touching the brakes in a corner the result is an unweighting of the rear axle and the towed vehicle tries to slide it. Very scary. My opinion of tow bars is they are fine with an RV towing a car, but I would be hesitant to use one where the weights are anywhere close. I used to put ALL my gear in the tow vehicle just to make sure the 40 was as light as possible. It tracked well, tight corners were never a problem (if your caster is correct) and I could even back it up to some degree. BUT, given the pass and other crazy hills out here, I would opt for a Tow dolly.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #27
Old 06-08-2012, 04:12 PM
I meant, as in fuel the engine. Fuel pump and 7th injector etc. with that pulley. The full meal deal from Gadget.
KDěRCH
  #28
Old 06-08-2012, 04:14 PM
F250 Super Duty with over the cab camper towing a 4Runner with special care to angle UP from the 4Runner toward the F250 (you do NOT want the tow bar to angle down unless you want the towed vehicle to pogo into the back of the towing vehicle in a panic stop!)...
The Chili is mighty but not mighty enough to lift a laden F250. She will be firmly planted on all fours methinks...
Towing with an Exploder... not so much.
Don't get me wrong, tow dollies are nice, but this is the cheapest one on Google...
http://www.google.com/products/catalog?q=tow+dolly+price&oe=utf-8&rls=org.mozilla:en-USfficial&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=6864649684470500514&sa=X&ei=GmzST8eKAcjRhAfQs9TRAw&ved=0CKUBEPMCMAE
KDěRCH
  #29
Old 06-08-2012, 04:30 PM
OilHammer's Avatar
When speaking angles, I was referring to "slight" angles. As in maybe 2" drop from end to end. In this scenario when you brake, the bar levels out perfectly. Short of a front end collision, there is no way the bar would lift the front end of my 40. In severe angles, you are absolutely correct that this could be problematic. For your situation, the RV towing rules apply. This link has drawings and engineering principles from BlueOx.
http://www.google.com/url?sa=t&rct=j...mlK0jVikppt4aw
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #30
Old 01-25-2016, 04:22 PM
bruce285's Avatar
bruce285 bruce285 is offline
Thinking of flat towing my 1964 fj40 to CM16 with my 1994 fzj80. Pro's and con's?
God has no Religion- Mahatma Ghandi
TLCA Member# 23562 KE0FUO kilo-echo-zero-foxtrot-uniform-oscar
'64 FJ40 Chevota heavily modded
'94 FZJ80 Toyota locked & stock
'09 Yamaha V-Star 1300 bagger
