Old 06-15-2012, 11:26 AM
ttubb's Avatar
ttubb ttubb is offline
Default $50 AGM Battery Charger
Found this at WalMart for those of us that have deep cycle marine AGM batteries.
http://www.walmart.com/ip/Schumacher...er/15140196#rr
KA7TLT - TLCA 13015
Old 06-15-2012, 12:44 PM
This does not seem to be a smart charger if I understand the operation, so there's a chance that it can stress batteries if used wrong. It requires that you select bulk, absorption or float. For a little more money the tenders like this one are less hassle, they sense discharge and use a 3-stage cycle. They don't have the bulk capacity like the one you show but they are true battery conditioners, so you can leave the battery connected all the time and it'll switch modes.
The XCS15 manual:
http://www.batterychargers.com/Docum...WB-0511-02.pdf
Old 06-15-2012, 12:53 PM
I use this one. I think it's only ~$20
http://www.batterychargers.com/Produ...tName=94026717
That's what was recommended for my deka agms by Hensley.
WØREK
Old 06-15-2012, 04:03 PM
$20? Not too shabby....
Old 06-15-2012, 05:11 PM
ttubb's Avatar
I have that also, however based on the other thread on batteries, I am getting one specifically for AGM batteries with a bit more amp capacity for quick charges. T
KA7TLT - TLCA 13015
Old 06-15-2012, 05:14 PM
ttubb's Avatar
The XCS15 manual:
•Microprocessor Circuitry, correctly charges AGM or Wet batteries. Not to be used for Gel batteries.
What is the difference between gel and AGM batteries?
KA7TLT - TLCA 13015
