Old 06-21-2012, 04:50 PM
Phrog Phrog is offline
Default can't get doors off 40
Well it's hot. And so it's time to take the doors off
the FJ40. I've soaked the door hinge pins in PB Blaster and whacked
them with a hammer. And they're not budging. Any other ideas? How
about simply removing the three bolts that hold the hinge to the door -
is that a bad idea?
-Phrog
Old 06-21-2012, 04:56 PM
Removing the three bolts will work just fine. It's not hard to readjust the doors when you put them back on.
Originally Posted by nakman
Old 06-21-2012, 04:59 PM
Removing those three bolts would do it and give you some more room to knock out the pins.
That said, give another go with a drift and a BFH (eat your wheaties and don't be shy) to get the pins out. The first time I removed mine, they were very stubborn and needed significant persuasion.
If you have a nice paint job, be very carefull to not scratch the paint. One of the benefits of the rattle can paint job on my 40 is the scratches I put into it are easy to fix.
Old 06-21-2012, 05:00 PM
I used a punch like this one to knock out the hinge pins.
Old 06-21-2012, 05:40 PM
If u do get pins loose, fold windshield forward because upper pin can hit it before coming all the way out
Old 06-21-2012, 06:05 PM
Default doors
Okay, thanks all for the ideas. I'll go to town on the hinges with
a punch and hammer, and if that doesn't do it I'll just remove
the 3 hinge-to-door bolts.
-Phrog
Old 06-22-2012, 08:18 AM
ttubb's Avatar
ttubb ttubb is offline
I had to use a rivit gun/air hammer to get mine out.
x2 on what Ige says. Terry
KA7TLT - TLCA 13015
Old 06-22-2012, 12:39 PM
Cover the paint below the hinge with cardboard and masking tape and hit it with a BFH.
Old 06-22-2012, 01:11 PM
Once you remove the door VIA the three bolts, you could also use a C-Clamp to jack the pin up.. but like others have said just smacking it real good should do it. Ige's right about the windshield though, the pin will run into it, so tipping it forward adds the clearance you need.
