Old 08-16-2012, 10:03 AM
Default Done!
Daniel and I got the pump rebuilt last night: 1.5hrs + 4 beers + pleasant conversation... very rewarding to have it done.
The kit from Rock Auto included all seals except for one: the little one that goes around the banjo bolt was not in the kit. I'll need to go to NAPA to find a replacement for it, plus the return hoses and I'll be ready for re-assembly.
Thanks very much Daniel - appreciate your help.
James DePaul
Old 08-17-2012, 12:46 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Great to meet you James and pay it forward. Glad we got you rebuilt and hope we inspire others. Its really quite easy, even if a few vanes fall out. Wear side faces clockwise and is farther from the center. Amazing how little wear there is after so many miles.
Old 08-27-2012, 04:24 PM
I've successfully completed the re-assembly following the rebuild. It was all well for a while but now I have another LEAK! Not on the pump this time - the bloody leak starts right where the supply hose leaves the bottom of the reservoir and feeds fluid down to the top of the pump. I can't tell if it's right at the host or above - could it be that I have a crack in the fluid reservoir?!
Seeing a puddle forming again under my cruiser brings tears to my eyes.. .
James DePaul
  #24
Old 08-28-2012, 12:47 AM
Inukshuk's Avatar
Is it a new hose? Unlikely to be the reservoir but I have a spare.
  #25
Old 08-28-2012, 11:02 AM
Daniel - it's a brand new Gates hose and a brand new clamp... If you have a spare I'll buy it off of ya. BTW - I may be in the are tonight or tomorrow, so I could pop over and return the wrench too.
Another thing: is it likely that I may need a constant-tension clamp on there, since it gets hot/cold/hot in there?
James DePaul
  #26
Old 09-13-2012, 09:43 PM
Originally Posted by coax View Post
I got my high pressure hose from Napa, and the pump rebuild kit from rock auto. It was a gates kit and seems to be working fine. Comes with engine block o ring but no bearing.
Did you just order the high pressure hose for an 80 series from Napa? Or was it a different hose that was a similar fit?
Originally Posted by nakman
  #27
Old 09-14-2012, 12:16 PM
I took Roobie's advice and bought the one from Napa...I looked it up online and took the printout with the part # into the Napa on County Line and Holly. They had one in stock
