Old 07-21-2012, 09:44 AM
coax's Avatar
coax coax is offline
Default Bikeman, question on your Fox Shox
How did you attach this mount to the top of the spring perch thing? I saw there are factory holes drilled there but not threaded. Did you unseat the spring and get a bolt up there somehow?
Or anyone else come across cool ideas for mounting a remote reservoir, specifically on the passenger side? I can't attach to the body of the shock as there isn't enough space to clear on that side, at least for my setup.
-Corey
'74 project pig (sold)
Old 07-30-2012, 08:59 PM
Nay's Avatar
Nay Nay is offline
I installed 2.0's about a month ago. Remotes are mounted to the shock, there is just enough room for the hose to extend up just barely into the engine bay.
I run 37's and I'm not putting anything high up in the wheel well....
Old 07-30-2012, 09:15 PM
coax's Avatar
Do you have eye tops or stems? My problem is on the PS side. There is a brake line bracket on the axle side that I think would hit the res at full compression if it was mounted to the body. I'll probably mess with it next weekend. Though on a related note since the revalve and installation on the rear the ride is much better.
-Corey
Old 08-05-2012, 12:29 AM
Nay's Avatar
Nay Nay is offline
Eye tops - and it is a close fit. And yes, great upgrade...
