Old 07-24-2012, 10:36 AM
baja1d's Avatar
baja1d baja1d is offline
Default 80 Maintenance Advice
Sometime in the next 3 days I will be swaping out my radiator that recently sprung a leak. Anything else that I should do while I'm in there???
Here's my list:
1. Swap radiators
2. Swap out power steering pump
3. Probably new belts
Travis Hurley– Owner/ C.E.O.
Old 07-24-2012, 10:46 AM
coax's Avatar
coax coax is offline
Here's my list:
1. Swap radiators
I guess depends on how crazy/money you wanna go. Having the rad out makes it way easier to replace the crank seal and the oil pump cover gasket. (You can get an impact gun with a phillips bit on it to take off the oil pump cover )
Also much easier to replace the high pressure power steering hose as well, and probably the low pressure lines too.
-Corey
'74 project pig (sold)
Old 07-24-2012, 11:17 AM
How about repacking your fan clutch? Oh, and swap on a 3-belt pulley to run on board air.
Old 07-24-2012, 11:30 AM
Replace alternator brushes? Less than $20 part and an easy swap if you access to the alternator.
Old 07-24-2012, 11:49 AM
baja1d's Avatar
Right on, thanks fellas
Old 07-24-2012, 11:56 AM
ttubb's Avatar
ttubb ttubb is offline
Do the belts, and get OEM as they are matched sets (dual belt). Unless they are really new.
KA7TLT - TLCA 13015
Old 08-08-2012, 07:03 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Default 3 belt pulley
Where can I find a three belt pulley?
X2 on the fan clutch if it has not been done.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 08-08-2012, 07:07 PM
20k cst in fan clutch
WØREK
Old 08-08-2012, 10:16 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
thermostat and coolant
TLCA # 20314
Step by Step Bed Bob
Old 08-08-2012, 11:51 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
PS lines. And when you re-install the radiator be sure not to pinch the transmission lines under it.
Don't forget that there are transmission fluid lines hooked up to the bottom of the radiator.
Remove your battery box to get the fan shroud out in one piece.
Oil pump cover can be done without impact gun. Tap the bit in exactly as instructed on the MUD FAQ.
x2 on alternator brushes.
Daniel Markofsky - Daniel@Markofsky.com KØFZJ
