Old 08-10-2012, 07:27 PM
Default Welding help needed
Have a small project that I need help with. Need some final cutting of a tube, welding some tabs onto said tube, welding said tube to two end plates to mount in the bed of my truck, and bending a 3/8" rod into loops to be welded onto the tube. So chop saw, angle grinder, torch (or turkey frier), welder preferred.
Not sure yet on timing, probably after work or on a Sunday, but can anybody help?
Old 08-10-2012, 08:18 PM
arthog arthog is offline
If you want to drive to my place, I can do it. We could ride after. Wait, Your a dad now, There is no more time for that. Let me know.
Old 08-11-2012, 02:31 PM
Hi -
I'm in Westminster, I could help you one night this week (or more if need be), I have a MIG welder, Chop Saw, angle grinder but I don't have a torch or tube bender.... If you could borrow these things then we could work in my garage to get it done. Let me know.
James
303-715-8196
James DePaul
Old 08-11-2012, 05:15 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Location ?
And I'm open every Sunday Do you have a welder ? Or are you needing to bring it to someone ?
TLCA # 20314
Step by Step Bed Bob
Old 08-11-2012, 08:36 PM
Thanks Terry! Yeah it's a bit of a drive up there, but I'll let you know if that's what ends up making the most sense!
Originally Posted by Overlander View Post
Hi -
James
303-715-8196
Hey James, thanks for the offer. I'm not bending tube, just some 3/8" rod, and maybe even a MAPP gas torch would be hot enough to help it bend?
Originally Posted by TIMZTOY View Post
Location ?
Hey Tim, I live in DTC, but I don't have any of the tools available, so I really need to bring it to someone who does. I could do it myself if I just had the tools available. Eh, the welding I would probably want to leave to someone with a little more experience than myself. Thanks
Old 08-11-2012, 08:59 PM
long commute but you can come down here for the help.
Old 08-12-2012, 07:48 PM
I could do it Thursday night if you want to drive up to Westminster (we can start anytime after 4:00pm). Let me know -
James
James DePaul
Old 08-12-2012, 08:15 PM
kurtnkegger's Avatar
Hey Matt, If you have any plans of what you need, and can get the materials together, I would be happy to get pieces fabricated, and then I could weld them on your truck a later time. If your schedule allows, I'd be happy to help.
Old 08-12-2012, 08:59 PM
TIMZTOY's Avatar
bring it buy my house on either thursday or sunday and ill get er done for you.
TLCA # 20314
Old 08-13-2012, 02:59 PM
baja1d's Avatar
baja1d baja1d is offline
Matt-
I work Tue, Thur, Sat but could help you out. I could use a hand getting the top back on my 40 so that I can get it out of the garage.... So frustrated with it that I'm walking away for a month!!! BTW, I'm in Littleton- Kipling/Bowels
Travis Hurley– Owner/ C.E.O.
