Old 08-28-2012, 08:22 AM
Bruiser's Avatar
Bruiser Bruiser is offline
Default Clutch Replacement FJ40 SBC Conversion
Well, my clutch went out the other day but luckily I was in the driveway. Now I have to replace it and thought I would see anyone had any suggestions on other services I should perform while I have my transmission dropped.
This is a SBC conversion to a stock 78 FJ40 4 speed.
Right now I am planning.
  • real main seal
    clutch
    Transmission Front Nose Cone Seal
    some new gaskets in several places
    dual-seal speedometer housing
I was also wondering if anyone knew what clutch I need to get to replace the old one. Right now the clutch I have works with the stock toyota clutch plate. Everything I have see online (mostly centerforce) has the centerforce clutch with and aftermarket gm clutch plate. I probably should replace the clutch plate anyway but is it safe to assume the centerforce plate will work with my flywheel?
Any help you all can provide is much appreciated.
Justin
__________________________
Justin - Littleton
TLCA # 18376
KE0EJV
78 FJ40, Rear Locker, 33's, power steering, sbc and so much more left to do.
Old 08-28-2012, 01:08 PM
nattybumppo's Avatar
Look at the clutches Marlin Crawler offers. Dean vouches for the 1200 pound one, but maybe for a SBC you should get the 1600 pound model.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 08-29-2012, 07:00 AM
Bruiser's Avatar
It does not look like Marlin offers one for a FJ40 SBC conversion. Thanks for posting up though. I saw a couple of other things I liked at Marlin that might go on the christmas list
Justin - Littleton
TLCA # 18376
KE0EJV
Old 08-29-2012, 08:10 AM
I think advanced adapters lists the clutch discs and pressure plates to use. Once you know the correct part numbers you can buy the parts locally. While you have it apart you should plan on getting your flywheel resurfaced before you install the new clutch parts.
Old 08-29-2012, 08:51 AM
Originally Posted by Bruiser View Post
  • Transmission Front Nose Cone Seal
do you mean the front bearing retainer gasket? why would you replace that? is yours leaking? they don't usually need replacement.
on the clutch, i did a 69 impala 6cyl iirc, but i can get you numbers when i get home. found a luk clutch real cheap online.
Old 08-29-2012, 09:27 AM
Bruiser's Avatar
That is good info Ige. I am not sure what is leaking, there is oil/tranny fluid all over the place down there. I actually think it is more likely the rear main seal that is bad and I do plan to replace that.
I also know I am leaking out of the back of the TC at the speedo housing and I will fix that too.
I certainly don't want to remove things I don't have to but while I have it out and while the fluid is out, I thought it was a good time to try to find the leaks.
Justin - Littleton
TLCA # 18376
KE0EJV
Old 08-29-2012, 09:29 AM
Bruiser's Avatar
Randy,
last time I had the flywheel out, 5 years ago, it looked and seemed perfectly smooth. You think it is a good idea to resurface anyway? Any shops you would recommend?
Justin
Justin - Littleton
TLCA # 18376
KE0EJV
Old 08-30-2012, 08:08 PM
this was my order from partsgeek.com
Parts Ordered
1969 Chevrolet Impala Clutch Kit Clutch Price: $81.85 Core: $0.00 Qty: 1 Part #: 04-072
Sub Total: $81.85
Shipping: $7.95
Handling: $0.00
Tax: $0.00
Core: $0.00
Total: $93.75
Old 08-30-2012, 09:25 PM
Randy,
Justin
If there are any rough spots or discoloring, get it resurfaced. If you are going to the trouble of putting in a complete new clutch you dont want it chattering because you cut corners on the flywheel. Any parts store, NAPA, Autozone, etc should offer flywheek resurfacing.
Old 08-30-2012, 09:40 PM
Bruiser's Avatar
Thanks for the advice everyone.
Justin - Littleton
TLCA # 18376
KE0EJV
