Old 08-31-2012, 08:17 AM
Justin, the transfer case front output nose cone gasket/seal could be a culprit. Pretty easy to check and make sure the bearing is in good shape too.
Old 08-31-2012, 09:32 AM
. Any parts store, NAPA, Autozone, etc should offer flywheek resurfacing.
however most don't have the services at their shops anymore. they farm it out and quite often won't get it done in this lifetime. i've had to pick my flywheel up twice from checker and vatozone when it sat for an entire weekend and didn't even get sent out. napa havana still has their machine shop, that's who i used to have do mine if i couldn't do it myself.
Old 08-31-2012, 09:40 AM
Our local CarQuest was very good about flywheel turning - did my first one for free so that I'd tell all my friends, and did an excellent job.
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Originally Posted by nuclearlemon View Post
vatozone
Classic
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 08-31-2012, 05:44 PM
Bruiser's Avatar
Bruiser Bruiser is offline
however most don't have the services at their shops ganymore. they farm it out and quite often won't get it done in this lifetime. i've had to pick my flywheel up twice from checker and vatozone when it sat for an entire weekend and didn't even get sent out. napa havana still has their machine shop, that's who i used to have do mine if i couldn't do it myself.
I have not been able to find a shop in west Littleton that still does it in house. napa told me their shop off of broadway still does it in house.
__________________________
Justin - Littleton
TLCA # 18376
KE0EJV
78 FJ40, Rear Locker, 33's, power steering, sbc and so much more left to do.
Old 09-01-2012, 08:55 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Clutch.
Pressure plate
Pilot bearing.
Throw out bearing.
Rear main seal.
Tranny fluid
Oil pan gasket if necessary.
The tranny front seal is not needed unless it is leaking (Hardlly ever leak)
Oil pan is just easier with tranny down. And might have to loosen to get rear main.
TLCA # 20314
Step by Step Bed Bob
Old 09-01-2012, 09:58 PM
Bruiser's Avatar
Richardo and I were able to get the transmission out and back in with the new clutch. It took longer than we expected, it usually does, because we had to take the transmission hump off as well as the seats.
The only thing that is a little concerning, is that the throwout bearing does not always spin freely when the cluth is not engage. It will spin with the clutch plate and flywheel. Sometimes it will pull back far enough so that it does not spin.
I have tried to adjust the clutch slave to but with no luck.
Does anyone know how serious this might be. It does not really make any noticable noise right now.
Thanks
Justin - Littleton
TLCA # 18376
KE0EJV
Old 09-01-2012, 10:19 PM
nattybumppo's Avatar
Make sure the ball on the clutch fork arm that holds the throwout bearing is all the way in the socket. There is a little two-armed retaining spring that it must push past to seat all the way. If it isn't all the way in there, the throwout bearing will do some funny stuff. Ask me how I know.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 09-01-2012, 10:25 PM
Bruiser's Avatar
Thanks, I will double check.
Justin - Littleton
TLCA # 18376
KE0EJV
Old 09-03-2012, 10:29 AM
I think the issue is with the fork and or ball being worn. The clearance setting between the throughout bearing and pressure plate fingers is very small; .06" inch according to the instructions in the link below. With a clearance that tight, any slop/play in the fork would account for the trouble we were having getting it set.
This link should bring up the installation manual for the Advance Adapters Chevy V8 the Land Cruiser FJ40, H42 4spd Tranny Adapter Bellhousing Kit you have. The instructions do have a specific part number for the pressure plate but I don't know if it cross references to what we used.
