Old 09-02-2012, 01:29 PM
Telly Telly is offline
Default Tranny fluid recommendations
Just picked up a 78 FJ40 (Luke's). I'm base lining the fluids. Seems like there are a lot of opinions on what 90w (GL-4/GL-5/synethetic/dino/ect) to use in the tranny, t-case and diffs. I searched but did not find what I was looking for. Whats the general consenses?
I also discovered my front diff fluid has mixed with the birf grease. Time for a knuckle and wheel bearing rebuild. With only 92k miles, the grease might be original I'll be posting a separate question on that.
Thanks.
Old 09-02-2012, 03:09 PM
ttubb's Avatar
ttubb ttubb is offline
Tranny and Transfer I use Redline MT-90. It is a synthetic designed for the older manual trans.
DO NOT use other modern synthetics as they will eat up the bushings in the older units.
KA7TLT - TLCA 13015
Old 09-02-2012, 03:42 PM
kurtnkegger's Avatar
I use dino 90wt. I figured that's what was available when mine was built (77), and would be good for replacement...
Old 09-02-2012, 03:56 PM
nattybumppo's Avatar
Originally Posted by ttubb View Post
tranny And Transfer I Use Redline Mt-90. It Is A Synthetic Designed For The Older Manual Trans.
Do Not Use Other Modern Synthetics As They Will Eat Up The Bushings In The Older Units.
X2.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 09-02-2012, 09:30 PM
I generally use what ever Redline product that matches the vehicles needs too when it comes to gear oil.
Old 09-03-2012, 01:22 PM
Redline it is! Thanks
