Old 10-21-2012, 10:58 PM
dr350jja's Avatar
dr350jja dr350jja is offline
Question ARB bumper issue
Well, now I have another dilemma. I recently installed the ARB front bumper on my Tacoma. When I called ARB, before the install, they said the bumper install would retain the factory front tow hook. Well, after the install, I realized the hook is there, but it is totally unusable, since I cannot get a tow strap or D-ring shackle on it. There is not enough clearance between the hook and the bumper components. Seems like it’s always something.
2006 Tacoma TRD Sport Dbl Cab Long Bed
3" Revtek lift, 16x8 Eagle Alloys, 285/75R16 Goodyear Wrangler DuraTrac,, Shrockworks Sliders, Cobra 75WX ST CB, BudBuilt Skid Plates, Daystar Rear Bumper Guard, ARB front Bull Bar, Warn 9.5 XP winch, CO2 tank, Yaesu VX-6R Dual-Band Ham radio
Jim
KD0MGU
IF YOU DON'T STAND BEHIND OUR TROOPS, PLEASE FEEL FREE TO STAND IN FRONT OF THEM.
http://www.sharetrails.org/
“Preserving Our Natural Resources FOR The Public, Instead Of FROM The Public!”
Old 10-21-2012, 10:59 PM
dr350jja's Avatar
has anyone run into this issue?
Jim
KD0MGU
Old 10-22-2012, 04:34 AM
baja1d's Avatar
baja1d baja1d is offline
Yes. Eventually just took the hook off because it was unusable and caught on everything. I just use to two holes that came with the ARB for my shackle.
Travis Hurley– Owner/ C.E.O.
Old 10-23-2012, 09:08 AM
farnhamstj's Avatar
What about a tow hook from an 80 or other toyota model?
KD0GWO
Old 10-23-2012, 09:38 AM
I just cut a square piece out of the bash plate to create enough clearance to slide the strap over the hook.
Old 10-23-2012, 04:20 PM
Gerdo's Avatar
Gerdo Gerdo is offline
Will a shackle clear?
2000 4Runner Sport, Lifted, 1/2 Locked, Winched, Some Armor, Fuel Tank Skidplate www.lilskipsoffroad.wordpress.com
Old 10-23-2012, 11:26 PM
dr350jja's Avatar
A shackle will not clear the way it is now.
Matt, I need to look at that again. The plate above the hook can be altered, but the bumper mounting bracket to the side of the hook may still not allow enough clearance to put a strap over it. We'll see.
I think I have a hook from a Land Cruiser that I will try.
I did get an email response from ARB and this is what is reads:
I believe (though it's been a while since I last installed a Taco bar) that the hook can be moved to the other side clearing space to access it. Please let me know if that's not the case and well look for a different solution to the problem.
Hopefully I'll have this figured out by the weekend.
Jim
KD0MGU
Old 10-28-2012, 09:17 PM
dr350jja's Avatar
Thumbs up
Well, the hook can't be mounted on the other side, since there are no mounting holes. But, it can be turned upside down and mounted that way. However, I don't think it's optimal, with the way the hook is curved. But, I don't see any other alternative.
Jim
KD0MGU
Old 10-28-2012, 09:53 PM
Gerdo's Avatar
What about a different hook? Maybe from an earlier year with a different shape?
Or, do a little cutting on the bumper to gain access.
Old 11-03-2012, 08:59 PM
dr350jja's Avatar
Thumbs up front tow hook
So the hook can be flipped over and mounted that way. But I'm not so sure I like the angle of the hook now. But, at least it's something.
Jim
KD0MGU
