Old 09-04-2012, 10:35 PM
Nice! I'm sure you'll be a great welder in no time..
so is there a bolt through the base of the jack into the running board? Do you have to undo both then? What about using some big knobs, like your windshield bolts, for quick removal?
Old 09-05-2012, 08:29 AM
Originally Posted by Crash View Post
Got to see the full on style show of you wearing the welding leathers and the mask to make the image complete. Early ideas for Halloween don't you know.
No one really wants to see that.
There is a bolt at the base. It may be ok without it, but I feel much better with the bolt. Yuppers, to get the jack off I need 19mm, 12mm and 13mm. I like your thinking on the knobs, it would really simplify getting the jack off. Perhaps it would be good to refer to this bracket as the prototype .
Old 09-05-2012, 02:03 PM
What about wing nuts vs. nuts?
For the base, you could fab up a 'holder' to secure the base in...Like what my rear bumper has. Although I like the simplicity of your solution. My only concern would be the off chance that the side the hi-lift is on is the side stuck in 2' of mud or whatever denying you access to that lower bolt/nut.
As always, you are an inspiration
Old 09-05-2012, 02:09 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 09-05-2012, 02:55 PM
simps80's Avatar
simps80 simps80 is offline
I like this a lot! nice work.
thumb nuts might work slick too, maybe the 'through' kind of thumb nut with a hairpin cotter pin through the welded bolt on the outside of the thumb screw.
Mike | KØSMP |
Old 09-05-2012, 03:52 PM
Yeah Mike, or something like that. Ricardo, check some of these out http://roganknobs.com/allclampingknobs.aspx
My thought is just a post would suffice for the base- the thing up at the mirror is going to hold it down, so you really only need to keep the jack from sliding off the running board, right? I bet you could get it down to just one knob and still keep it secure, possibly with some rubber pads to dampen the rattles and also add a little load to the clamping?
Speed of deployment, IMO, is all the difference in how useful a hi lift is on the trail. I've actually been in recovery situations where a less than ideal solution was even implemented, because someone couldn't or didn't want to find their keys, or find a wrench, or get it down, or unload everything to pull it out...
Old 09-05-2012, 04:08 PM
LXBRADY's Avatar
I use wing nuts. The bumper mounted hi-lift comes off in a jiffy, saving the day!
I also carry a bottle jack because hi-lifts suck.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 09-05-2012, 04:11 PM
Burning steel is a blast, that came out great bud.
Old 09-05-2012, 05:57 PM
Me too! Ever try to simply change a tire with only a HiLift available?
Old 09-05-2012, 07:21 PM
Crash's Avatar
Crash Crash is offline
Yes, and a bottle jack wouldn't have worked nearly as quickly and efficiently. It's good to have all bases covered. Needing three different size sockets or wrenches is not quick or efficient. On the other hand, it makes it a little more difficult for someone to steal!
