Old 09-04-2012, 08:36 AM
rockrod rockrod is offline
Default Marzocchi Parts in Denver??
Do any of the local bike shops carry Marz fork parts? I need a replacement RC2 cartridge. The compression adjuster is broken off the bottom of the cartridge.
I reality, I want to do a full rebuild and change the oil, seals, ect. It's a 2006 Marz RC2X fork (170mm travel I believe).
2004 Kona Stinky dee-lux.
Old 09-04-2012, 09:32 AM
arthog arthog is offline
dirt labs in boulder. their on valmont, next to the fix bike shop, and right next to the valmont bike park. all they do is rebuild forks and shocks. ask for mike or luby.
Old 09-04-2012, 10:39 AM
Caribou Sandstorm's Avatar
WOw, nice find Art Hog!
My Fox Floats are leaking, taking it in to a local shop in Denver tonight. The guy said that my v-brake version are no longer available, so this may be one of the last times I can get them serviced. Maybe if I have any trouble I will go to Dirt Labs in the future.
I guess your supposed to service these forks every so often?? Mine were fine for 9 seasons with no service but maybe with a little service mixed in they might last longer..
My rims don't support disk brakes, so I have a major expense ahead of me at some point..
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 09-04-2012, 11:11 AM
For Fox, particularly older Fox shocks and forks, PUSH is very good. Yes, you are supposed to service them periodically. :-) I usually change oil once a year and have the bushings replaced about every 2 or 3 years. Fox does not change stuff very often and they can be fixed or rebuilt, even really old ones.
http://www.pushindustries.com/
Rim brake forks can still be found, although I think for 2013 Fox completely dropped lowers with canti bosses. I think the other brands have models that support them still, though they'll be pretty low end forks now.
Old 09-04-2012, 11:26 AM
Thanks for the info Dave, you are a "research guru"..
Chris
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 09-04-2012, 11:47 AM
Dunno about that, been using PUSH for a long time, probably 8 years now. We have nothing but Fox forks and shocks.
Old 09-04-2012, 03:20 PM
I called and spoke to mike at dirt labs. He said he would look around but was doubtful that it's possible to find an rc2 cart.
I think I can salvage it for now just by making a small groove into the end where the knob used to be and then use a flat blade driver to turn the adjusted. Apparently it's a common issue and the knobs get amputated frequently. Avalanche downhill sells a cart but it's more than $400. I am not going to spend that on this bike. It's just a starter. I will rebuild the fork with new seals and change the oil but that's about it.
