Old 09-05-2012, 04:17 PM
ttubb's Avatar
ttubb ttubb is offline
Default Maddening Leak
I have a slight leak at the juncture of the water pump and the block on my FJ-40. Crazy thing is it only leaks after sitting, not when the engine is warm or running. I have tightened the water pump bolts and it reduced the amount, but it is still there. I am afraid I will have to pull the pump and replace the seal.
Anyone have this problem before? Terry
KA7TLT - TLCA 13015
Old 09-06-2012, 04:47 PM
maybe the water pump is going bad? I believe there is a weep hole that will leak when the pump is going bad. I'd stay on the safe side and just replace the pump, even if it's fairly new. Bad things happen when water pumps seize.
Old 09-06-2012, 04:58 PM
I think I've had every 2F water pump leak ever, including the pump-to-block. I would get an OEM gasket and put a little bit of FIP on each side of the gasket, and reinstall the pump. I suspect the cardboard gasket in there has died of old age.
If the pump shaft has no play and the bearings feel good, the pump itself probably still ok.
Some OEM '78-era FJ40 water pumps have been discontinued -I think you can only get a factory one that has the oil cooler fittings. My '78 does not have an oil cooler (it's not a Calif. model), so I don't know quite what I will do when the water pump dies. Some of the non-OEM pumps struck me as lame in the past - the output hose flange was glued onto the pump body, rather than being part of the casting.
Old 09-06-2012, 05:57 PM
ttubb's Avatar
It is not leaking from the shaft or weep hole, just the gasket area pump to block. Now that I posted, it has stopped. Go figure.
Thanks for the suggestions. Steve's suggestion was what I was thinking too.
The engine was completely rebuilt about 3000 miles ago, but we did not install a new water pump at the time. I am certain we did install a new gasket. Terry
KA7TLT - TLCA 13015
Old 09-06-2012, 10:17 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
what he said..
if its leaking or seaping then its time to replace it. even if its just the gasket. replace the pump because you have to tear it apart anyway
TLCA # 20314
Step by Step Bed Bob
Old 09-07-2012, 08:48 AM
ttubb's Avatar
Originally Posted by TIMZTOY View Post
what he said..
I agree with your reasoning. Thanks, Terry
KA7TLT - TLCA 13015
