Old 09-19-2012, 10:35 PM
Bruiser's Avatar
Bruiser Bruiser is offline
Default Wanted - Speedo housing
Does anyone have a speedo housing sitting around for a pre 78 transfercase. I broke a bolt off in mine, then proceeded to brake an extraction bolt in the hole, and then tried unsuccessfully to drill it out. So, I could use a fresh start if anyone has one.
Thanks
__________________________
Justin - Littleton
TLCA # 18376
KE0EJV
78 FJ40, Rear Locker, 33's, power steering, sbc and so much more left to do.
Old 09-20-2012, 09:22 AM
Is this your new housing with the double seal? I'm assuming it is one of the cover plate bolts. Do you have a picture that shows what is there to work with?
At one of the CM Wrenching sessions, we had a broken stud for a lock-out hub on George's truck. We used the drill press to steady things up as we put a hole in for the extractor. It took some patience but we were successfull in getting it out.
Similar issue (hub stud broke) on the trail with Kevin's rig and I watched Robbie use a small pointed punch to tap the bolt remains counter clockwise and back it out.
Worst case scenario would be to drill the entire thing out and tap the hole for the next size up.
Was your drill bit sharp? When we (actually Tim N.) were doing George's we had a sharp bit that made small tight metal spirals as it did the cutting.
Old 09-20-2012, 10:10 AM
Pretty sure ive got.a couple
Old 09-20-2012, 01:56 PM
Bruiser's Avatar
Yep, this is my new double seal. I think I may already be in a worst case scenario situation as I too hastily tried to get it out with thoroughly planning my attack (lesson learned). Now I don't have a flat surface to work on.
I tried to take it to a professional machine shop but I had one guy quote me $100 and am having troubles finding any machine shops at all. I can post up a picture tonight but it is pretty ugly now that I let my frustration get the best of me.
Justin - Littleton
TLCA # 18376
KE0EJV
Old 09-20-2012, 01:57 PM
Bruiser's Avatar
Thanks IGE. I will shoot you a PM
Justin - Littleton
TLCA # 18376
KE0EJV
Old 09-20-2012, 03:31 PM
Bummer. Post up the pics and perhaps the Rising Sun collective can help salvage the situation.
Old 09-20-2012, 08:30 PM
Bruiser's Avatar
Ige, looks liek your PM box is full.
Justin - Littleton
TLCA # 18376
KE0EJV
Old 09-20-2012, 11:04 PM
didn't find it yet...pretty sure i have at least one..i'll keep looking
Old 09-23-2012, 11:05 AM
found it...sent you an email
HTML code is On
