Old 09-25-2012, 05:36 PM
coax's Avatar
coax coax is offline
Default My First Welding Project AKA Rear Bumper Build
For a long time I've wanted a better way to carry gas than on the roof. The long term plan also includes storage underneath where the spare was for tools/oil/etc that I don't access often and would rather not keep in the interior.
I wanted a bumper that:
1. Was bolt on.
2. Not built for serious rock crawling, but would provide a happy medium of protection and carrying capacity vs. the weight penalty. (Doesn't need to hold a 39" tire, don't need to support the full weight of the cruiser if its up against a rock, etc)
From my limited research there either wasn't anything in this category out there or it was going to be hard to come by. Either way, I decided I'd give it a go and attempt to build one. There are a ton of builds on Mud and I just kinda took pieces and parts from a bunch of different ones to come up with something.
Ended up taking ton more time than I first estimated. Oh well, I like projecting and whatnot.
Its a mix of 1/8, 1/4 and other random scraps. Got the spindles from 4x4labs w/ sleeves. Latches and spring pins from mcmaster.
The recovery points have a 5/16" plate that goes through the bumper main box, and then additional 1/4 pieces welded on the sides.
Overall the construction and welding went OK. I designed most of it to be as "redundant" as possible. (IE each arm is drilled through and slipped over the spindle as opposed to just welded on there.) I also practiced with some gussets and other small bits to help beef it up where thin metal was used and get some practice. The welds came out ok. Not too consistent yet. Oh well! Pretty much just turned up the Promig 140 to the highest setting and used flux core. Other tools used were an angle grinder, chop saw, and drill press for the larger holes. Thats pretty much it. Was lucky to borrow a friends shop for the duration cause I work slow!
The spring pins hold the bumper both closed and open at maybe a 110 degree angle. The tire and gas cans are angled back just a bit. The sleeve for the spindle was 1/8" welded into the 3x6 box, with an additional 1/4 plate in the middle for strength.
Paint was just some rustoleum brush on....Not very durable at all. Will have to figure something else out long term.
I spent a few days down in beef basin/elephant hill and the bumper did great. Didn't take any big hits but it held together. Time will tell the story on durability, though even with some pretty good bumps and whatnot I didn't notice any movement on the tire.
The Test Run!
-Corey
'74 project pig (sold)
Old 09-25-2012, 06:20 PM
Very nice Corey!!
Old 09-25-2012, 10:54 PM
RedCreeper's Avatar
nice work
Kenny Jones
TLCA #19056
08 TT FJC
82 Scrambler (Scraps)
81 Scrambler (Sassy)
07.5 Dodge Ram 2500
Old 09-26-2012, 12:18 AM
ScooterFJ40's Avatar
ScooterFJ40 ScooterFJ40 is offline
I've seen a lot worse welds and designs
Way to improvise!
1988 Toyota Xtra Cab, Four Linked, 22RE, 40's at the moment.
Old 09-26-2012, 08:08 AM
RicardoJM's Avatar
That is pretty sweet.
Ricardo Maestas - Bio Page
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
Old 09-26-2012, 09:13 AM
That was a ton of work!
Old 09-26-2012, 06:57 PM
Very nice! I need to do something similar for my 60; the only bolt-on ones I can find are Kay-Mar and 4+, and both of those have stuff I am not cranked up about. I definitely need that wrap-around corner protect as I already buggered up my sheet metal on Jenny Creek.
Old 09-26-2012, 08:03 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
very nice..
TLCA # 20314
Step by Step Bed Bob
