Old 09-22-2012, 04:00 PM
Default '96 FZJ80 Rear Wiper
Problem - rear wiper switch is turned off but rear wipers are stuck on intermittent. Problem with the switch? Anybody else ever heard of this problem? MUDsearch didn't reveal much...
Old 09-24-2012, 05:45 PM
Odd...Haven't come across this issue...yet
Old 09-24-2012, 07:34 PM
I never had a problem or heard of it. If you can find a plug for the switch - unplug it. That should indicate if the problem is in the switch or in the motor assembly. I'm betting it's the switch.
Old 09-24-2012, 07:39 PM
Shark Bait's Avatar
You have an 80?
'12 GX460
Old 09-24-2012, 08:51 PM
I guess there's a panel in the driver's D pillar and there's a relay in there or something that can get wet and cause shorts that cause weird problems. Time to start investigating deeper...
Originally Posted by Shark Bait View Post
You have an 80?
No
