Old 09-23-2012, 04:34 PM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Default Clutch issue
Hey guys,
I have a clutch issue that I am dealing with on my 1980 FJ40. It has gone from intermittently not shifting into gear from neutral to not working at all in a few days' time.
Here is a little history on this issue from last week. Any input or ideas would be much appreciated.
http://forum.ih8mud.com/40-55-series...h-problem.html
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 09-23-2012, 05:09 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
without clicking on the link it sounds like a hydraulic issue (air in the system or bad seals)
what i have also ran into with alot of toyota's are that the entier bracket that the 3 pedals are atached to, cracks. then when you push down the clutch pedel the bracket flex's there for the pedel moves the entier stroke but the master only gets pushed in 1/2 way. causing the clutch to only engage 1/2 of a stroke, causing what your expearincing
TLCA # 20314
Step by Step Bed Bob
Old 09-24-2012, 09:41 AM
cbmontgo's Avatar
That makes sense. I think the cylinders are original to the truck as well, so it could easily be a seal.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
