Old 09-27-2012, 11:34 PM
Default Front LCA OEM bushing orientation? 80 series
Removed my caster correction bushings and going back to OEM bushings as I installed caster plates.
So my question is how to orientate the OEM bushings? There are two holes 180 degrees apart in the rubber part. Where should I place those in relationship to the ground?
Old 09-28-2012, 09:12 AM
A picture from Christo's site show's the holes in a horizontal orientation:
http://www.sleeoffroad.com/technical/tz_ome.htm
Scroll down the page a ways.
Old 09-28-2012, 09:14 AM
sleeoffroad's Avatar
Search Mud. The diagram is posted somewhere. Early trucks was one way, then they changed it. Can't recall which is the correct way now, but it is on MUD.
Christo Slee
KØSLE
www.sleeoffroad.com
Old 09-28-2012, 04:04 PM
Got a text from Onur. Horizontal is the word.
Old 09-28-2012, 04:08 PM
coax's Avatar
coax coax is offline
Good to know. I really want to switch away from OME bushings back to stock, but am tempted to go with the drop brackets rather than caster plates. (given my lower lift).
-Corey
'74 project pig (sold)
Old 09-28-2012, 05:57 PM
Here are the diagrams
