Old 09-30-2012, 09:38 AM
Caribou Sandstorm's Avatar
Default 100 series dual battery set up
I am thinking of moving ahead on adding a dual battery set up.
Normally I go out on trips with others but I am considering more solo trips in the near future and would like the added security of a back up battery and running all my stuff on a separate battery.
I would like to keep it simple and low cost and then phase in the extra stuff later. I also wanted to first use my existing battery for the back up battery, reason (cost). Edit..looks like I need to use the diehard Marine for fit size to Christo's battery mount.
I am going to get a Die Hard Platinum for the cranking battery and eventually a die hard marine battery for the second battery.
Other than the mounting brackets, what else do I need for the most basic and low cost set up available?
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 09-30-2012, 10:17 AM
Crash's Avatar
Crash Crash is offline
http://www.bepmarine.com/home-mainme...d-vss-500-amps Controlling two Odyssey 1700s is a piece of cake for this switcher. Waggoner uses the http://www.bepmarine.com/home-mainme...d-vss-275-amps and I think it is working well for him. About as simple and complete as you can find. The Group 31 1700s will fit Christo's battery tray without problem.
Old 09-30-2012, 10:59 AM
I have this and made my own cables. I need to hook it up in the hundy.
http://www.powerstream.com/battery-isolator.htm
simple and inexpensive. no need to NL and others.
Old 10-01-2012, 01:09 AM
Cool thanks guys!
Chris
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 10-01-2012, 10:03 AM
throw a battery in the trunk for emergency starting needs if you want the simple solution.
I use a BEP marine switch in the 60 and it works well. I think it is rated at 300 amps. I have winched with it a lot and pretty much never thought about it after installing it.
I think the write up is here somewhere.
Old 10-01-2012, 10:18 AM
Crash's Avatar
Marco's writeup helped me get the job done. The BEP switch he uses has been superseded by the one I have.
Old 10-01-2012, 10:39 AM
How much are these BEP switches? Do I order direct? edit figured it out.
Chris
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 10-01-2012, 11:20 AM
cool man, let me know if you need some help. gimme a buzz any time.
Old 10-15-2012, 10:38 AM
Update, I picked up a Sears Platinum Marine 34 on Sat. 219.00
The 31s were an option I was considering but that is a mammoth sized battery, so I went with a 34.
Hoping to install the 34 today.
Chris
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 10-15-2012, 11:21 AM
That's what I've been using for the last 5 years as my second battery. It's held up well and only just recently seems to be weakening a bit (in the sense that it doesn't seem to hold a charge as long when I'm parked for several days). Mine needed a booster to make it tall enough to use the stock trays - I think it's a piece of 3/4" plywood.
