Notices
Old 10-22-2012, 08:57 AM
CardinalFJ60's Avatar
Default terrible interference when fridge comes on.
Anyone who's been on a run with me since I got the fridge will attest that it puts off some wicked RF interference when the fridge compressor kicks on. To the point where I have to squelch it out to about 75-85% of the travel on the squelch knob. With my HT, I can walk toward the rear of my 60 when the fridge's compressor is on and hear the intereference, I walk away...no more sound. so it's got to be from the fridge.
No one else seems to have that issue (??)
What could be the culprit? Should I just throw on a Choke? any ideas on how to track this down would be great.
I have the fridge wired straight to the aux battery with 10g. it is however still on the cig lighter plug.
Old 10-22-2012, 09:00 AM
Where is the wiring for the radio? Do they share any part of the circuit, or run right next to each other to the aux battery?
Old 10-22-2012, 09:06 AM
Romer Romer is offline
My guess is the ground. The outlet you have the fridge, might try taking the ground directly to a chassis bolt rather than running it back. Same for the Radio.
If they are on the same positive (fuse), might try finding separate sources
Old 10-22-2012, 12:29 PM
Default close quarters for sure...
Both are run straight to the Aux. battery (separately of course, each on 10g) and IIRC they run right next to eachother under the hood...'cept that the Ham Power stops at the console, and the fridge runs straight back along the PS interior
Old 10-22-2012, 12:31 PM
Default grounds could be suspect.
They used to be on the same positive, then I ran a separate power/ground to the fridge to try to fix that interference - no improvement with that...hmmm...ground is the next I'll check.
Old 10-22-2012, 12:36 PM
Could be a loose or improper ground. Might also check to make sure the ground from your battery/alt has a good connection. I remember having to take teh bolt off and grind a bit in the engine block on my 40 to get a good contact
measure from battery to a point on the chassis, should be very few miliohms. measure from the fridge ground to chasssis and should be the same
Make sure all your connections are tight with good metal to metal contact
Old 10-22-2012, 03:00 PM
Or, the motor in your fridge that runs the compressor could just be bad i.e. a brush has a slightly too large gap to the armature and is sparking. Or there is an inadequate or loose ground inside the fridge chassis.
If you know someone that has the same fridge as you do, try plugging their's into your rig in the same configuration as yours. If the noise goes away, its the fridge. If it stays, it is somewhere in the eletrical system of your truck.
Old 10-22-2012, 03:55 PM
Default GREAT idea.
Doh. why didn't I think of that!?? Oh Perrrrry..where are you?
Old 10-22-2012, 04:08 PM
Jacket's in Lafayette, dude..
You could also just stick a battery back there, then wire the fridge up directly to it- bypass everything. Sometimes it's easier to diagnose if you can see the whole circuit in front of you..
I think you're on the right track with the ground though, just pull the cig plug out, pop off that ground wire, then run something completely separate to what you know is a solid ground. If that fixes it, then do it again but more prettier.
Old 10-22-2012, 04:47 PM
Default how about...
how about just leaving it plugged into AC and disconnect the DC?
