Old 11-05-2012, 03:35 PM
baja1d's Avatar
baja1d baja1d is offline
Nothing. Just walked away for awhile
Travis Hurley– Owner/ C.E.O.
Old 11-05-2012, 03:51 PM
never mind.. I was still going down the stuck in gear path. I had forgotten about the previous thread.
KDØGWX
Old 11-05-2012, 04:37 PM
baja1d's Avatar
Sounds like a clutch issue or issue with the clutch fork. Esp when it only happens with the clutch engaged.
Wes, can you elaborate on this?
Marco, I was never really confident that the tranny was in neutral when I assembled the t/c. Hence the resent tear down.
Old 11-09-2012, 07:16 AM
PabloCruise's Avatar
Intereting!
I would love to do an H55f & split-case in my Piggy, so I'll be watching this.
I wonder if is clutch related as well
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 11-09-2012, 08:46 AM
baja1d's Avatar
Spoke with Robbie at length about this issue & he really doesn't think it's related to the tranny or t/c. A lot of people have mentioned the new drum parking brake assembly as the cause but neither of us are 100% convinced. Unfortunately, when I mated the t/c and H55 I didn't have much to reference regarding a manual. So for piece of mind I've disassembled the t/c and will be pulling the transmission. I'll check the clutch and reassemble the tranny & t/c following the manual to the tee/ referencing this thread:http://forum.ih8mud.com/40-55-series...e-rebuild.html. I'm currently cramped for time so it may not be until after thanksgiving.
Old 12-05-2012, 09:36 PM
baja1d's Avatar
Finally back at it, decided to ditch the drum parking brake and do a rear disc conversion. Unfortunately I've hit another snag or potentially discovered the root of my problem. It appears that the spines on the output shaft of the H55 has become misaligned. At any rate, I cannot get the transfer input gear to seat completely. Anybody know what I can do to remedy this besides a complete tranny rebuild? A custom made SST with a 3' extension & torque’d to as much muscle I can give it isn't working!!! I'm currently considering a Dremel tool to each spine just to get this gear to slide another 1/4".
Old 12-06-2012, 12:07 AM
powderpig's Avatar
You are going to need a new shaft, that will brake at the best/worst possible time. I know that the gear may get over the shift in the splines, but that will be a weak spot and will not take the load over time. Sorry to see that issue creep up, first time I have seen pictures of this happening.
Old 12-06-2012, 12:18 AM
baja1d's Avatar
Bummer!!! Any idea where I can source a shaft?
Old 12-06-2012, 08:30 AM
Toyota has them. You could call up beno or Cdan and see if they can give you a deal.
Old 12-06-2012, 09:13 AM
I also made up a complete set of tools to take it apart with. I think Dan has the tools right now.
http://forum.ih8mud.com/60-series-wa...-made-sst.html
KDØGWX
