Old 11-16-2012, 09:41 AM
Default Head Job
I took the 525 apart last night. I think all in all it looks pretty good. Piston and Cylinder look very clean with little to no scoring.
I am thinking new rings, rebuild the head, quick go through the carb and call it a day.
The cam shaft where the seal for the water pump goes does look a little munched though.
Old 11-16-2012, 09:44 AM
And I figure since it is down for a little while I might as well go through the suspension. I am taking the front forks and rear shock to hitchcock and will service all the pivot points and bearings on the bike. the rear swing arm bearing creaks a bit and the steering stem bearings feel like they have a detent they fall into.
The pipe is kinda munched also. I tried the water trick last night and it helped a little bit. I am just gonna leave it in the back yard and let it go through a bunch of freeze thaw cycles and see how it progresses.
Old 11-16-2012, 09:45 AM
FJ40 is next.
Old 11-16-2012, 10:37 AM
Yeah that galling on that shaft looks mean, so do you try to machine that down & sleeve it somehow? Or get a new one?
Old 11-16-2012, 11:17 AM
Yeah that's where all the coolant was going. Hopefully the Dave Hopkins guy can do the head work and look at this also. If not I'll work on it... I agree it looks surprisingly gnarly now that I look back at the photo.
On the bright side, I talked to Neil at Hitchcock... I am going to visit him after lunch to drop off the front forks and rear shock
Old 11-16-2012, 12:09 PM
I'll bet a new cam shaft is rec'd. Are you going to replace the valves?
Old 11-16-2012, 02:08 PM
egesledder's Avatar
egesledder egesledder is offline
So that's why your bike had a nice sweet coolant smell to it.
What you really need is the high compression 570 kit Marco:
http://thumperracing.net/index.php?r...&product_id=57
Maybe you'll be able to keep up after that.
Drew
'85 Turbo Pickup
Old 11-16-2012, 02:21 PM
.. Nice first post
Old 11-16-2012, 03:26 PM
. Nice first post
Yeah no kidding! tough room today in bikeland.
Old 11-16-2012, 08:53 PM
Yes very nice.. That gave me a good chuckle..
Perhaps you can keep up the next time we go to the go kart track. Much less manly than dirtbikes I know but it's all I got.
Suspension is at Hitchcock, still waiting to hear from Dave to send off the head. Been looking for cams.. I'm pretty sure I want to stay stock if possible.
Also if anybody is interested in my auto clutch and lhrb in trade for a stock setup let me know.
